[ROM][BETA] Quattrimus ICS
I'll take a screenshot next time. It was odd, lol.
Yea, Virgin Mobile doesn't allow Roaming at all, yet you're not the first to report momentarily roaming.
I've read here, and in other Android forums of Virgin Mobile users, typically with the Optimus V, have experienced several cases of Roaming, with a wide variety of several Roms.
sent from my un-dead sammich.
If you ask me they should let us roam like sprint. Hell i would even pay $10 to $20 more then i do now for the roaming like sprint does so i could use the phone in more places.
Correct, no need to wipe data.
Try 729max 600min on savagedzen.
You just gotta spend a lil trial and error messing with several combinations to find what works best for your phone.
Thanks and i think the issue was that it was still on InteractiveX I changed it to proformance it can overclock just fine now.
So is the AOKP 31st version the only one going beta 2, or is cm9 31st going as well? Also, when is it and can I just download the 31st file now or will the beta 2 release differ from it in any way?
I am so tired I was up all night playing with aokp
Both will be beta2, and I believe every build after including 7/13 will be considered beta 2
First off i LOVE this AOKP ROM. By far the best I've had on my phone to date. I wanted to flash the new nightly but the main link is broken. Anyone else running into this issue?
While I'm in GB what are the files for the hot spot
Edit: Nvm I'm back with Quttrimas because the home button didn't work and I got stuck in the browser after changing my theme
You guys ever see that post leslieanne put up about them supposedly implementing roaming? Think it said it was supposed to have been July 1
So still no youtube fix for aokp?I just find it hard to beleave that after all this time noone has figured this out.....
Yeah but that was only a rumor spread by an uninformed public relations individual.
Reactions: nitestalkr
what now i keep getting no space left for anything i did 512MB and in setting it says i have used 212MB from the 179 MB so i know it is somewhat working but no space for a 2.12 MB file...?
visionarysearchist
