[ROM][BETA] Quattrimus ICS
LOL Im just wondering why are we focusing on the roaming indicator when the mms, auto rotate, phone mic, and youtube video are entirely broken? I mean if we as a unit say it wont work, its one thing, or if we were asked for particular advice on how to help, i would. But something as small as the roaming indicator...
Reactions: lesheifner
It's a big deal to me. I'd like to know if I'm connected to 1X or 3G, and with the roaming indicator on I cannot tell that. It's important to know how reliable my connection is before I start downloading or uploading something.
Also, Powmining's fix for MMS works just fine for me.
Videos cannot be fixed until Qualcomm decides to listen to this petition: https://developer.qualcomm.com/forum/qdevnet-forums/multimedia-optimization-qdsp/13248
Auto-rotate is not what's broken, it is the sensors that are broken and I'm trying to help with getting information for tdm so he can develop a fix for it.
Phone mic works fine if you turn on speakerphone. Yes, it is annoying, but I'd rather have ICS than to not have to deal with this on Gingerbread.
Okay that actually makes sense, thanks. Around my house, the junior high destroys all phone signal by some kind of material they built it with. Most people use wifi, and literally anywhere I go besides my home, if it's signal, its 3g. Of course we have 4g here too so I guess that probably changes something.
Quote from Qualcomm on the petition
Re: Petition: Release OpenMax codecs for arm v6 OMX IL libs ...
19 Jun 2012, 04:16 pm
#31 (Top)
In a previous forum post, we indicated that we would look into this request and, unfortunately we are not able to support video codecs for ARMv6 OMX IL libs for Qualcomm's QDSP5 on MSM7x27. The architecture of MSM7x27 cannot support OpenMax video codecs for ARMv6 OMX IL on QDSP5 running on Android Ice Cream Sandwich (ICS).
We appreciate the feedback and will continually monitor this thread.
Forum Master"
So then, no video support?
#31 (Top)
Forum Master"
Ha.. More like they don't want to support it. Just sad they don't want to support their product which is still in phones being sold today. Because it is 'old'.. Something will have to give. there are millions of devices needing this out there (literally). All we can do is sign, wait & cross our fingers.
So, this is probably a stupid question but, what makes youtube like a slideshow on AOKP but not CM9. Would it be possible to just copy files from CM9 to solve that on AOKP or is that easier said than done.
EDIT3: Does not work. Sorry for confusion.
EDIT: Yeah, worked just fine. A copied over a few files. So i'll do a little more checking to see which one helped.
EDIT2: just libmediaplayerservice.so copied it over from the cm9 build and youtube is no longer a slideshow on AOKP.
HUGE help, thanks! :D
Thanks to @tdm for pointing me over here to the Vortex forum, so that I could thank @kappacat! Awesome work! I don't often watch videos on my phone, so it's not a major issue for me, but it appears to be so for many others. There's at least one inquiry per thread page stating that YouTube is broken, etc. So you've just made many people happy, and helped to clean up the threads all at the same time!
I am still having the slide show after replacing the file and flashing?am i doing something wrong?
sorry for confusion but well I'm confused. I moved over libm.so and any other one that said media and videos worked. UNTIL I flashed gapps. cause I was testing without that. Since I just restore my ext each time. then it didn't. So I don't know what is going on but it worked originally.
Just a side note here. AOKP 7/4 build. My processor has been entering sleep regularly from what I can see. Battery lasts over 24 hours easily with regular use. I do have data disabled most of the time though, I use wifi. At 53 percent now, after 26 hours.
Sent from an icy Vortex utilizing Tapatalk 2.
Just flashed AOKP 7/10 here!
Phone reboots when I try and open power menu by long pressing the key. Locking screen works like normal.
I can't get mobile data working correctly for some reason. Some apps worked while others had trouble. Some couldn't reach google servers specifically.
going back to CM9. AOKP is looking neat and I like the new boot screen.
Did you do a clean install? Is any one else having these problems? I'll probably flash tomorrows build. Also, going on 36 hours now. ;)
Going to test out the latest builds of CM9 and AOKP soon and report back with my findings. :)
EDIT: CM9 seems fine and stable, no issues as far as I can tell except for all the current known issues. :P
Flashing AOKP now...
EDIT2: AOKP is running good. The issue with the power menu popping up twice is half-fixed, it now closes the menu before opening another. Still tries to open 2 but it's much better than before.
EDIT3: Under AOKP I noticed that for the carrier label when you pull down the status bar says Extended Network. This is what it would say for me with the stock ROM. However, the "R" is still up by the bars indicating roaming. Also, the carrier label is cut off on the lock screen. I did see this mentioned in the Optimus V thread as well I think.
How is the battery looking on CM9 these days?
Sent from my LG-VS660 using Android Central Forums
I have not used CM9 extensively so I'm not sure about that, however AOKP has decent battery life for me. It's not as good as what BobZhome's CM7 ROM was, but I can make it at least a day without a charge so it suits my needs.
Got the 7.12 nightly for AOKP, and my battery hates me again, similar to the CM9 battery issue. It went from 66% to 30% over the course of 45 minutes, and all I did was check my email and add a picture to a contact. The only difference in the way I'm using it is that I'm using the Nova Launcher (which I've fallen in love with.) I've also had some issues with the gallery not loading local or Google Photos. Still no luck with the YouTube slideshow issue. Still no sensors, low mic, etc.
Couple notes:
clodfelterac in the VM670 thread found some property tweaks that reduce reboots. I'm putting them into the next nightly build so test 7/13 vs. 7/14 to see if that improves things.
The ROM directories were getting cluttered. So I created a new nightly directory and the new nightly builds will be placed there, starting today. I'll update the webpage links soon.
Oh, and I haven't forgotten about the sensors issue. I'm busy with the new kernel right now. But I'll try to find some time to look at this soon.
Reactions: kappacat
Couple notes:
I haven't had any issues with reboots, but I'll go head over to the VM670 thread and put clodfelterac's changes in my build.prop and see if any new issues come up. BTW, my CPU clocks are 729/128 on smartassV2.
Couple notes:
Awesome. By the way, when it comes battery or lag issues, are there any screenshots or specific info that will be really helpful to you? Apps installed? Mem info? CPU info?
probang
