[ROM][BETA] Quattrimus ICS
I'm going to check LG's VS660 Froyo source and see if it contains the proper eri.xml.
EDIT: nope. Nothing there like that.
EDIT2: Here's the eri.xml from stock ROM: http://pastebin.com/QnQYwyBD
If there is anything else you need from the stock ROM let me know and I'll try and pull it out.
Reactions: tdm
MMS is still broken in the test AOKP. as is the roaming indicator. Exhibits same behavior.
Reactions: tdm
@tdm I don't know if this will be of any help, but you can find the VS660 source code from LG here: Open Source Main
Select Mobile Phones and type in VS660. I believe it contained something for ami304 that might be of interest. You could also compare it to the VM670 and see the differences I'm sure.
Reactions: tdm
Yeah thats my plan, thanks. :)
P
Bad news. Didn't work for me. Though now the roaming indicator is gone :p Still no mms though.
o_o weird you got the opposite outcome xD
Edit: I think the changes that were done on AOKP-Test made it act differently xD
Actually, I had made a backup so the test would be a fresh install. I had already restored the backup when I used your fix.. So interesting indeed. :D
Sent from my LG-VS660 using Tapatalk 2
Edit to fix typo.
Edit to fix typo.
very.. someone tested it and it gave them MMS but still had the roaming indicator :confused:
Yeah.. Even as I Swype this I have no roaming indicator..
Sent from an icy Vortex utilizing Tapatalk 2.
Using the beta1 release of AOKP I was successful with using Powmining's fix for MMS. Didn't fix the roaming indicator as that is packaged in framework-res.apk for AOKP. I'm going to see if I can modify that and stick in the eri.xml I had gotten from the stock ROM.
That's odd though cause CM9 has eri.xml in the framework-res.apk BUT it also has the one in /data. In the other hand aparently AOKP dosent have it in /data :-\
Reactions: tdm
Thanks I wasn't aware of that.
I have CM9 and after I used the fix i made I don't have Roaming Indicator and I have MMS working. and I think.. since the fix is suppose to replace the eri.xml it actually adds it to /data since It's not there in the beginning.
I think this may be of help. It is the build.prop from a stock 2.2.1 ROM, although there might be a couple little tweaks it's nothing important. Most of note is this:
ro.cdma.home.operator.alpha=Verizon
ro.cdma.home.operator.numeric=310004
http://pastebin.com/raw.php?i=58Bf7Vmj
Reactions: tdm
Ok, so I opened up Terminal Emulator and tried running ami304d, and this is the error it throws:
Cannot open KR3DH!!!
Cannot open KR3DM!!!
Not sure if that's of any help but I thought it might leaad in the direction of fixing up the sensors.
EDIT: Quick search in LG's VS660 kernel shows kr3dh.c and kr3dm.c in /drivers/input/sensor/
I guess that'd be the place to look for this :)
EDIT2: kr3dm.c is a 1:1 match between your kernel and the VS660 kernel, however the kr3dh.c has some changes.
rosannejoy555
