[ROM][BETA] Quattrimus ICS
Between cm9 and aokp I use aokp. The many customizations are nice plus I get awesome battery life. As for stability I have not noticed a difference between the two. Just make sure to up your low to 480 in overclocking to avoid freeze ups.
Reactions: JimJ2mz
Waiting for rotation to be fixed on the Vortex~
Like many others, I am really anxious. But the progress TDM made on this ROM is absolutely amazing and well done! :D
I guess I'll stay with cm9, even though I have a tendancy to flash the newest nightly everyday. -_-
Reactions: tdm
really would like to see the low volume fixed.. turning on speakerphone fixes it but is annoying..
Hm...The low mic isn't noticeable for me. Is it because of CM9 or are both versions having similiar issues? 0_0
I have a kernel with the VS660 version of the AMI304 driver here. This is a flashable boot image for CM9, not AOKP.
Anyone running a recent CM9 nightly (within the last week, say) please give it a try and see if it fixes rotation.
My bad, I didn't build properly. I'll have a new test zip shortly.
hm...still not working. strange.
hopefully i flashed it right. still no rotation...
should I try another way?
Excuse my lack of intelligence, but how do you get the logcat?
Sorry, I'm still new whatsoever.
And sorry for the wait, I had to do something.
To get a logcat, you first need adb on your PC. Search Google for how to find and install that. Once it's installed, I believe you need to open up a cmd window to run it, as it's a command-line tool.
Now, connect your phone to your PC and run "adb logcat". It will dump the buffer and continue to print messages as they are generated.
Or you can run eg. "adb logcat -d > logcat.txt" to dump the buffer to a file named logcat.txt.
There will be lots of data. You can probably find tools to search through it for particular strings. Even notepad should work for simple stuff.
Reactions: JimJ2mz
Does logcat show any errors related to AMI304?
Assuming I am to flash this over the existing rom. My recovery reads this:
Install from sdcard...
Finding update package...
Opening update package...
Verifying update package...
E:No signature (13 files)
E:Verification failed
Installation aborted.
That is with "try2"
Darek
