the other trick to try is to flash harmonia froyo, or the stock Rom, and let it run the activate app to reactivate your 3g. after it works again, go back into recovery, wipe /data and /cache and then flash pac or whatever again.i tried the a28-cm-10.1-20130220-thekraven-LS670 rom as well without flashing the CronMod-INT2EXT+_signed ... still to no avail .. 3g worked on the stock rom but all the roms after cm 9.0 i never get 3g to work.. can you share the steps used and roms, gapps, etc used that have worked with you?
Just a heads up, the Gapps MediaFire link is down.. :\
How to make hardware buttons switch?
I see that there were some bluetooth fixes added to the new PAC build. Has anybody gotten BT to work on this?
I wish!
still did the exact same thing. turns on, finds device, but never pairs.
