cyberdalek
- Feb 12, 2011
- 266
- 53
- 0
Found this posted by Fitsnugly elsewhere.
Sent from my Galaxy Nexus
Twitter! This usually means it'll be integrated into the next build.Where do you find this at?
Beamed from my GneX via TaPaTalK.
XDA
The cherry picks state allow nav bar background to be themed. Has anyone figured out how to use this?
I don't see any new settings.
I assume this would allow the nav bar background to be changed by a theme (using the theme chooser).
Hah, I thought you found something in this build, nice, I was gonna wait till this weekend to flash something but this looks promising.
Are you sure it's not in this build? Once you select it in settings, go back, and hit the menu dots when you're in a text. I'm on CNA now, but I'm pretty sure I had these on the last Jelly Bro I ran (8/11).
I love that I can type the name of a contact and bring up their number, a la Sense. This Rom is TIGHT.
Has anyone encountered bugs yet? I have not noticed anything since yesterday, flashed it 24 hours ago.
Running 813 and no such setting. I will flash the latest 814 and see if its there.
No bugs and there is a new build up on their web site![]()
I am using a theme as well. Not seeing it.
Need someone who has actually used this feature to chime in. I would think there would be something in the navigation bar settings to check if you want to theme the background or not at least.
Well, I believe it's strictly controlled by the theme, and if the theme supports it. For instance, I just downloaded ghost, applied/rebooted, and voila... themed nav bar.
Do I count as using the feature now?
