[ROM][CM10][JB] Euroskank JellyBro
Ok so I got 2 questions, not sure if bugs or what happened.
Flashed 813 and 7-26 gapps last night. All went smooth no issues.
When I was using the gnx today when ever I got an email or text, I pulled down screen to see what I had, the small block that shows what you got either email/text/ etc was larger than normal and I was able to read most of either the email or tewt with out tapping to open it up. Is this a euro thing or a setting I can change?
Also when google put back my contacts it missed some, was that google issue or mine.
On a great note the battery life is awesome I am at 45% ( I use a 3800 seido) usually have that at 5pm when its time to go home.
thanks for any leads!
It's a Jelly Bean thing. You can pinch it closed and open.
You no like?
Reactions: Xanth269
So I've been out of the loop for a bit... I'm still sporting AOKP B36 (hey, it works flawlessly!) and want to move onto JB. From what i see, i should be hopping on the Euroskank (pun intended...).
My question is, is there any plan for a stable version any time soon? I'm not the type to flash nightlies, preferring only the milestone updates, to borrow AOKP phraseology.
Does ES plan on having milestone versions and any idea if they will come soon?
So how are we using this Emoji support upgrade?
Never mind my wife pointed this out..
But I can't send any text messages now. Oh boy. Anybody else got SMS problems?
Fixed it! (dam SDmaid app erases everything!)
I sent some emotioncons to my contacts and they couldn't see them.
I always sync my contacts manually before flashing. That way I'll know any new ones will be back.
Unless the receiving party has the same emoticons set, they won't (at least, as far as I have ever seen) be able to see them. Some 3rd party SMS apps will, however, offer you the option to send the emoticons as an MMS pic to ensure that it's seen. I don't know if the ROM cooks that particular feature into the native SMS app... I doubt it.
Hope that helps,
Matt!
Sent from my toaster (rooted).
Reactions: greyhd
I wish it was a new contact, it was the wife's info that did not come back, (maybe a message?? lol..) , so crazy question how do you manually sync?
Well, I believe it's strictly controlled by the theme, and if the theme supports it. For instance, I just downloaded ghost, applied/rebooted, and voila... themed nav bar.
Do I count as using the feature now?
:D
Sent from my Galaxy Nexus
Where did you find this theme? I NEED it!
Ah ok. I'm using the 726 gapps and so far no issues.
Yes. Thank you. That's awesome looking.
Does your theme specifically state it supports nav bar theming?
Sorry. This quoted the wrong post. This was meant for redeyerev. Tapatalk won't let me edit my post either.
Nice. It did it again. I quoted my own post and it quoted a different post. I'm done quoting for today. Apparently, something is wrong somewhere.
Is GApps still necessary when dirty flashing? I'm assuming so but I'm want to be certain
I was still on AOKP B36 until last Monday because I was waiting for a JB milestone. Didn't want to give up my stability and customizations. I've been on about a dozen JB roms since then and "all" of them have been just as stable as ICS AOKP (ironically AOKP was lagging behind on JB). At this stage of JB roms I probably have more custom options now than B36. Seriously, don't wait for a milestone. JB in general is so much better. You'll see;)
Reactions: mraviator
