[ROM][CM10][JB] Euroskank JellyBro
It wouldn't work for me when I tried it less than a week ago, even with a pull down. That's odd.
It works for me when I pinch in or out.... Like zooming. Try it. Let us know.
Sent from my toaster (rooted).
910 is up. Option for lockscreen clock to be centered has been added but the status bar option has been taken away.
What about the 9/9 build? Does that have both?
He mentioned on twitter that it the lockscreen clock was not working cooperatively with the status bar clock.
It seemed to work fine for me...I had them both centered, though.
Ah, figured it out. I'm on maguro and he was talking about toroplus on twitter. I know this is a Toro thread, but I haven't found one like this in the gsm forum.
In the past 5 or 6 updates, are you guys seeing any performance improvements, or are they mostly comprised of bug fixes and/or new features? I ask because I'm on 0827 and have no bug issues at all (at least in the way that I use my phone). I'm wondering if I want to mess with an upgrade?
Just make a backup before upgrading and if you notice any bugs just restore back. I spent some time running AOKP but yesterday flashed 9/10 and in the last 24 hours haven't noticed any issues seems just as smooth as before.
Does anyone else here use Handcent and noticed that captions don't always send over with picture messages? There will be a large space for the text would have been, but there's nothing there when the person receives it....
I just noticed on 9/10 randomly during phone calls that whoever I was talking to wasn't able to hear me...just flashed 9/11 build. Hopefully it will fix it.
I really like the stock quick reply text feature that has been implemented!
YeP... Same EXACT problem here. Phone would secretly mute, then signal drop, then phone process error.
Gonna update to the next nighly
Good.... but cell standby sucks and playing a normal game kills the battery
This is completely normal. You used it minimally over 12 hours and drained less than 60%... it makes sense that the largest use of battery, percentage wise, was cell standby. When you aren't using it much then standby or background processes (such as Android OS) will make up the largest percentages of overall use. Completely normal.
How did you get battery life that good after playing games. Settings?
SwiftKey seems EXTRA sluggish on the newest build. The keyboard lag gives me a stomach ache.... For real.
I've uninstalled and reinstalled already.
Latest is up and ready for download. Those that haven't downloaded the latest nightlies might want to check the latest cherry picks. :D
I have a question. What gapps are you guys using with the latest build?
hincapie
