I don't think CM10 ever had circle clock. They like to use the battery bar for some reason. I always had to use themes to get the circle clock.I'm on the latest build as of now, and I can't add the AM/PM to my clock (it's greyed out). Also, did they disable the circle clock?
Does formatting system wipe your apps?
Quick question I clean flashed 9/13 couple days ago and I've been having issues with my WiFi falling asleep after 15 min or so, any way to fix this? Also I'm on Franco m5 kernel
I've noticed this too. Wifi sleeps when the phone sleeps, but wakes when the phone wakes. Is this how it is for you? I'm still running 9/14 and stock kernel. I don't think Wifi sleeps while I'm using the phone, not that I've noticed anyway.
Yep thats exactly what's been happening and no doesn't seem to happen while I'm using it, but my standby battery usage is kinda high because of it. Just clean flashed the newest build though so hopefully it won't keep doing it.
Question...I flashed the first cm10 "monthly" that was released on my Verizon galaxy nexus and I'm just wondering if there is a known issue with 4G LTE on that ROM. Reason I ask is because I only get reception on CDMA only mode and when I go to CDMA/LTE, the signal comes and goes about every minute. This is a replacement unit because I had issues with my camera on my previous nexus, but on my previous nexus I never had an issue with LTE and I was running the cm10 nightlies. I wanted to ask first before I call Verizon and get another replacement. Any info on this will be greatly appreciated. Thanks!
