[ROM][CM10][JB] Euroskank JellyBro
Thanks gang.
I actually switched from CWM to TWRP?.
What is missing from the gapps besides maps and play?
Team Win Recovery Project. Maps and Play IS in gapps so you might have to reflash that again.
Thanks gang.
If you switched to twrp, update that too. The euroskank gapps include maps and play. Are You using 121212 version?
So I just unlocked and rooted my phone for the first time. I went through CWM and installed and flashed CyanogenMod 10. My phone has now had the CM circles spinning for about 10 minutes. Is this normal? How long does it normally take?? Thanks!
Did you flash the gapps? Did you flash 4.2 or 4.1?
I was trying to flash 10.1 (Nighlies). Not sure if I had a bad link or what. I reinstalled to SD and got it to work, but as soon as I flashed the GAPPS, it would just crash the phone. I flashed 10.0 (stable), then the GAPPS, and that seems to work just fine.
Downloaded the latest nightly from the link in post #1. There should be no problem running it. Clean install.
I am running this rom and ever since installing everything is very slow. Extremely slow. Plus I am getting huge battery drain that I never had using bugless beast or AOKP.
I haven't downloaded the latest nightly (I don't think). Thoughts?
Are you on the stock kernel? Try lean or franco's kernels.
Anyone else having memory issues with the 223 build? My memory goes down to 80 and really slows down the phone to the point where apps don't run right.
Not yet, radios were not available when M2 came out.
Well radios would not have been incorporated anyway since they're separate from ROMs. I was more talking about whether they incorporated the 4.2.2 base. Oh well :(.
Good question. Hopefully in the nightlies they will.
Just flashed from the last Euroskank before 4.2.x and I cannot seem to find where the development tab is within the phone settings. I can't enable the ADB thing, any ideas to where it is?
Hi bawoo, the last Euroskank prior to 4.2.x is dated what? 11-26 or so? I am still running 4.1.2 dated 10-19 with 07-23 xoomdev GAPPs and like it. Stable, does everything I need. No real need to update to 4.2.x as I see it.
Emmhodes
