[ROM] CM7.2 Port for Optimus S by thekraven 3/9 zvd only
Re: [ROM] CM7.1 Port for Optimus S by thekraven 11-03-2011
Damn me. I clicked on the full version link in OP. And the link under barebones still downloads 10-6.
does anybody have a theme where the signal strength looks close to the stock one with the 5 or 6 bars instead of the 4 bars that I find on most the themes. pref in cyan or an aqua color
That drives me nuts too. I haven't found a theme that has over 4 bars. But I did find the HTC Elegant theme that has bars that look more like the stock 6 bars.
Could anybody explain how I can use all hdpi themes on my phone now? I could not use any that were hdpi only,but since the last update I can. I have my LCD at 130 and I use chainfire3d also.
Sent from my LG-LS670 using Tapatalk
I always wondered if I tried to use an HDPI theme and it didn't work what happens lol...can't say I've ever tried :P
They usually just say not compatible with device. But since the last update most if not all of them are on my phone anyway.
ok so im wondering will this work as an update for Drew's cm7 or is it completely a new rom. I'm starving for a new rom since i flashed the last stable vesion from Drew. i know if i cure my phone of the VD radio to the VH radio i would have to REroot, and honestly i don't trust myself to do so just yet. Am i just being to cautious?
I would wipe everything just to be on the safe side. This rom is 3 months newer than drew's last update. A lot has changed since then.
I just flashed it over my old one from zefie and didnt have an issue
The 11-03 barebones link leads to a 10-6 build.
currently dl'ing full rom until it is available.
also on my current build of 10 22 when setting the auto brightness
the widget stops changing icons and shades just stays on and shows the "A" sun icon
I think that auto setting caused a few problems, I disabled it and restarted my phone and everything worked fine again.
Re: [ROM] CM7.1 Port for Optimus S by thekraven 10-23-2011
I think i got it to work. I think it just moves the date down and the Carrier label to the bottom. I probably won't be doing anything with it at the moment, still too beta for me. Maybe if it served some new functionality, but it just moves things around. But the ics patcher is on XDA to use if you want this mod.
It should work with the Achep ICS theme and the other 1.4 ICS theme This one: [Theme] Ice Cream Sandwich | 008-build-56 | 28.10.2011 - xda-developers
Here are the 10/23 ICS status bar patches based on the lastest CM7 framework and SystemUI, It has transparency, but ICS themes don't have it. ics10.23.2_patch.zip and undo ics10.23.2_undo.zip
version1
Click to view quoted image
fixed version 2Click to view quoted image
could you please tell me how you got your power controls like that? acheps theme didnt change that for me, and also how did your notifications get the black backround like in the second picture, mine shows them like the first picture did
I modded zdunes patcher to include some graphic files. If you use those patched files on that post with the 10/23 builds Acheps ICS theme, it should look the same. Or are you making your own patches? I'll have to see which Achep version i used
im on your 11/03 builld. i cant use those. anyway you could make an 11/03 that had the power controls and graphic files? id appreciate it <3
RAP25
