[ROM] CM7.2 Port for Optimus S by thekraven 3/9 zvd only
Re: [ROM] CM7.1 Port for Optimus S by thekraven 11-03-2011
Is it possible to dirty flash the updated rom over an older version of this rom? Or should I still do a full wipe before flashing?
I removed ADWLauncher and pushed ADWLauncherEX to the system/app folder. Don't seem to have any problems yet. Just wondering if I could remove other not so important apps.
Like pergerson6 said, if you dirty flash a new version of this app then you will lose ADWLauncherEX since it will be overwritten by the stock ADWLauncher.
I'm having problems getting any of my cyanogenmod settings to stick! Anyone know how to fix this?
Sent from my LG-LS670 using Tapatalk
I usually delete books, car home, and dsp manager, i have had trouble with dsp manager and just install EQ equalizer. And i personally just do not use car home or books. Just my 2 cents lol! Damn THANK GOD for recovery!!! I dropped my phone while it was installing 11/3 cm7.1 and thought CRAP, but recovery saved my butt again lol:p
I'd like to know the answer to this question as well. I'm about to try to dirty flash this one and I'll report back on my success (or lack thereof ^_^).
This ROM is f'ing awesome! Installed in a snap, and effortlessly applied the ext4 mod. Thank you!
I've tried dirty flashing but for some reason I can't get my phone to reboot. I always dirty flashed drew's roms with no problem. The kravens roms seem to need everything wiped! At least on my phone.
you can try it and may or may not have issues like force closing ect. nandroid backup first! or try just wiping cache and dalvik cache flash the debugformat.zip then the rom followed by gapps, should be good to go!
I dirty flashed and some of my apps have disappeared. Oh well, I always nandroid before flashing anyway. I'll restore and try what fenderman said above before going for a full wipe.
BTW: Cigman, I'm running the data2ext4 mod too. Do you reboot once after flashing and before installing the mod or did you just flash it all before rebooting?
Anyone getting Korean characters (I think its Korean) in the market? Just flashed the latest build yesterday and a few other things so I may have caused it. Like this:
Fixed it by clearing Market data. It was weird cause it was showing on my desktop browser also.
Now to find a ICS adw theme...
Waiting for barebones. Was about to ask when will you be uploading but remembered the 1st rule of CM :P
Here's the 11/3 Barebones. Please check your MD5. Fixed link now
11/3 Barebones http://dl.dropbox.com/u/28170720/11.03.2011-Barebones-CM7.1-IHO-Kraven.zip
md5 4739c8df1506de81f3c6bef797206d10
There is a barcode scanner error on this build. Like with Google goggles. Working on that tomorrow. Camera works fine though.
Reactions: Invincible Madness
11/3 Barebones http://db.tt/RanAfKck
Why is the file named 10-6 when its really 11-03 or 11-04??
Oops i must have copied the wrong link
phalgal
