[ROM] CM7.2 Port for Optimus S by thekraven 3/9 zvd only
Re: [ROM] CM7.1 Port for Optimus S by thekraven 11-12-2011
Also, the number of ringers available on this ROM is insane!
I do have a problem. I enable USB Tethering and the phone immediately disconnects the USB and won't enable it until I restart the phone. Windows comes up with "unidentified device", and at first showed LG Optimus V, even though I have an Optimus S, and I do have all possible drivers installed.
--EDIT--
I just rebooted the phone, and Windows then identified and installed all devices.
I have noticed that if I disable USB debugging, enabling tethering will immediately disconnect the USB and "Unknown Device" will show up in device manager. What I want to know is if USB tethering works on the phone, or do I need a seperate app?
--EDIT--
Nevermind, it seems I would have to use an app to tether.
Has anyone tried the new GingerKernal v08 yet? Wonder how it works with this rom...
Videos do not have picture and touch screen during turning device on are issues but other than that its great. Its designed for zvh roms not zvd cm7.
New build. 11-20-2011-CM7.2-RC0-IHO-Kraven
  • Builds are now 7.2 RC0
  • Lots of CM7 patches and fixes from 11/13 till now. See the more indepth change log here: https://github.com/CyanogenMod/android_frameworks_base/commits/gingerbread
  • Includes: fixes for the phone signal hiding. Reverted a CM7 video cam error. Wifi signal fixes.
  • I'll need to make all new patches for transparency, center clocks, and ICS statusbar too.
  • DOWNLOAD in OP. Thanks.
Re: [ROM] CM7.1 Port for Optimus S by thekraven 11-20-2011
Can we apply this update without wiping the phone like when first installing?
--EDIT--
I should mention that it seems the 11/12 version is ignoring the set ringer for some contacts and applying the default ringer
Seem to not be rotating screen...
Edit:
nevermind, alright after reboot...
The file name still says cm7.1. Is this OK?
BTW, the new boot animation looks cool!
The 11/20 version does work much better than the 11/12 version.
In the "about phone" it shows as being 7.2
Uploaded the 11/20 patches in the OP.
I have CM7.1.01 11-12 build installed, can I just flash 11/20 over the top?
Or do a fresh install?
It's running great right now!!!
best optimus s rom I have run & I have tried all of them...
Thanks
Sorry .... I missed a page
Will backup, try a dirty flash 1st
Sent from my HP Touchpad using Tapatalk
r3dpuk3
