[ROM-CM9]Paranoid Android Tablet UI~August 15th,2012 MIC FIXED
Re: [ROM-ICS-CM9]~~~~Paranoid Android TABLET UI~~~~June 27
It's Very very odd, I myself think its a software issue with the different DPI settings.
What did you port from? And DPI causes messed up keyboard.
I used Bobzhome's CM9 Rom as a base and the optimus S port of Paranoid Android.
I need cm-9.0.0-RC0.thunderc.BobZhome.06162012.zip anyone have the link?
If you port that, your just porting an port of a rom.
I wouldn't port that rom, in my opinion, since you could flash it as it is.
Well the optimus s one doesn't have wifi or 3g working. Mine does
That's because they have ZVD, ZVH, ZVj, and so on. We don't have to worry about that stuff because we don't get updates. Understand?
Afaik our zvd baseband works with you guys' roms, zvh/zvj doesn't. But if it was simply the problem of it being the wrong baseband, we wouldn't get service at all, meaning we wouldn't get a phone signal either.
Probably a porting process. He probably threw out some files in the ETC with the Optimistic p500 files.
Could I ask for one favor from the OP? I'd like to try porting Paranoid Android to another device, how did you go about it? I'm sorry, I really don't know where to begin doing any of this, and I'm not sure where I would have to look to get the files I'd have to look for
Sent from my LG-E739 using Tapatalk 2
I just remembered that, and they were included in there. o_o
I can't even find the Play Store in the zip. Paranoid included certain Gapps. I'm guessing modded ones, because the play store is compatible with alot of apps.
just for your future refrence, if you didnt already know, its in system/app and its called vending.apk or something like that
I know that. :p
Wasn't called Vending, Market, or Play Store. Couldn't figure out what.
is this still WIP if so im gonna start useing it as daily
cinemacritic
