[ROM-CM9]Paranoid Android Tablet UI~August 15th,2012 MIC FIXED
Gonna start from a new base when I het home, eventually and hope it works.
Re: [ROM-ICS-CM9]~~~~Paranoid Android TABLET UI~~~~June 27
EDIT: never mind they didint got it working :(
Thekraven told me tdms old builds were like that, try to use one of his latest builds and if u use drivers from GSM phones that could be the problem.
Ill start on new builded rom when i get home. No access to a PC, I'm at a hotel.
You guys are welcome to help though, I will give credit and whatever else. :)
All I can do is help test, but I will be more than happy to do that
Looks like I know where to start now. Hopefully by then, its released.
Ill be back somewhere between now, and next week(maybe).
Microphone doesn't work when calling... please fix.... otherwise perfect rom.... good job :):)
I know that this may be blown off, bit BACKside has the bottom status bar function. And it works, I've used it from time to time. But if you could get the bottom status bar, with the nav buttons working in this ROM, that would be awesome!
sent from my un-dead sammich
Reactions: jonny5449
Our s port has bottom statusbar
I don't care who u are :p this is an awesome song :) http://www.youtube.com/watch?v=dxytyRy-O1k&feature=youtube_gdata_player
It comes from the size of the source, MDPI, HDPI. Paranoid Android is originally HDPI and up.
Gingerbread has nothing to do with CM9.
Gotmy port working just
Gotta fix the wifi and keyboard
Sent from my LG-P500 using Tapatalk 2
What did you port from?
I'm working on one through mobile using solide explorer and root explorer.
@zakman--- does the mic work on yours?... (they can hear you, you can hear them)?...
I just made my own port with different roms and still no in call mic.
mohamsn
