[ROM]COLD AS ICE-CM9+Paranoid Android LS670 11/20 ZVD basesband Alpha19
I had a clean install of a10F with cam and audio fixes. to test i disabled my SSID broadcast, forgot my network rebooted wasn't able to connect. I then rebooted to recovery flashed cm9.a10F.test1boot.img.zip wiped cache and was able to connect.
Are you guys getting any intermittent lags like gmail freezing up with the data2ext mod. Some apps just freeze up sometimes and I have to force close them and I'm not sure if it's just me.
no patches installed here, think a10f was up to snuff at the time i installed it, i dunno i work alot and find it hard keeping up with progress here, will try the patches. thanx for checking for me, i'll let you know how it goes i am kinda an instagram junkie.
and yea 12mb! i am kinda an app junkie to...
Click to view quoted image
Sent from my LS670 using Tapatalk 2
Re: [WIP][ROM]COLD AS ICE-CM9 Sprint LS670 5/6 ZVD basesband Alph
Has anybody else had a problem with the time syncing? Sometimes the clock on the status bar falls behind the time on the lock screen. My guess would be that it displays the last time that the phone was active. (Not dark, not at lock screen.)
The clock is still hit or miss for me...I have a widget on my homescreen that seems to always be correct. (Your clock app should show the correct time as well).
Yes, quite a few of us have posted about it.
Confirmation of previous issues:
* WiFi Hotspot doesn?t work. When I check the box for the CM9?s ?Portable Wi-Fi hotspot?, it just hangs, saying ?Turning WiFi on??. FoxFi (v1.81.3) fails with the error message, ?WiFi mode has failed on your phone. Please use Bluetooth mode instead.? Quicksettings (v1.9.8p2) can?t select ?On? for ?WiFi Hotspot?. WiFi Tether starts with errors and doesn?t work. WiFi Adhoc enabler starts and seems to run, but does nothing useful.
this works.....
Reactions: Zhara
Try an app called clock sync from play store, it keeps the lock screen and status bar clocks on time and synced
sent from my device using XPB ICS Tapatalk 2
Link Download Isn't Working For Me.... Using 3G & Dolphin Browser HD
Sent from my LS670 using Android Central Forums
It Worked After What You Said!. Thanks!.
No problem. It happened to me too but remember to switch back to android because mobile website like youtube, google, facebook etc. Will look like if you were on a desktop computer
Sent from my VM670 using Android Central Forums
Question anybody having any luck with adobe flash player 10.2 or 11.0
I am having no luck. I know its a hardware acceleration thing but thought I would try
I tried that app but it still doesn't seem to help...maybe there's a setting I'm not checking but I have it on automatic sync...
I haven't been using it with the last kernel. Still lags, but only by 2 minutes over 3 hours.
non-broadcasting wifi - No go
also tried the test boot.img - settings FCs
No, it's and ics thing. They just started to get ics support in 11.1 but was spotty. You have to hope someone cracks the newer version for arm6.
The 11.1.115.8 linked one installs, but needs some files in the /data/data/com_adobe_flashplayer/lib folder. Otherwise it won't read anything at http://www.whatismyflash.com/
Reactions: fenderman
Thanks the kraven its something that can be lived without! I figured it was an ics thing
I would really like to know what actually happens, what gets changed, when we put our phones in airplane mode, turn off, pull battery, turn on and leave airplane mode? Why does this give our phones such fantastic battery life? Is it something that can be changed in the kernel? In the rom?
SIPdroid notifications pulled down from the status bar show no text. Just the red, yellow, or green
You can use the built in dialer as a sip user agent now. Simply goto the dialer, press menu and goto internet calling, to set it up. It works great and it even shows the ice cream answer/decline screen, you can even use the stock dialer to call out using your sip account.
Glad you're loving the ROM. Hopefully having said this, I gave you an even more awesome way to use your sip account than SIPdroid
Yeah I got flash to load more on 11 than 10 I tried placeing the data files but it just doesn't load its just missing the point I guess:p
It'll just take a lil time is it possible on ics the data files need to be elsewhere?
Thekraven: I'm having data problems. It connects but it goes slow and the new kernal 10 messed up my data period.
Sent from my VM670 using Tapatalk 2
I think us with optimus v should not post bugs on a OS forum.
Reactions: res6jya6
rob805213
