[ROM]COLD AS ICE-CM9+Paranoid Android LS670 11/20 ZVD basesband Alpha19
Re: [WIP][ROM]COLD AS ICE-CM9 Sprint LS670 5/6 ZVD basesband Alph
Can someone make an option in the settings to enable the on screen buttons??? would be cool.
Reactions: thenameisnigel
Can someone mirror to 4shared since MediaFire is blocked at work and by the time I get home, I'm sleep. :/
Sent from my LS670 using Android Central Forums
thekraven asks very specifically for no mirrors.
Is anyone, other than me, having issues getting the usb to connect in the rom? I'm getting a systemui failure. I first thought it was because I had dicked around with uot kitchen in 10f, but it persisted across to 10g.
I've been working around it by going into recovery to move files.
Settings, storage, (menu) USB computer conncetion, choose Mass Storage
Kind of strange, but I have wifi sleep policy set to "never" so wifi is always up and running while I'm home...but occasionally when I wake up my phone it isn't connected and then starts to re-connect. I'm on 10F...wasn't doing this before IIRC....
A fix for the mediafire problem is to toggle "request desktop site" on and mediafire will load up. I dunno what's up with the site but it works.
Alright, so, it turns out that my battery bug report may not have been a bug.....my battery level DID eventually decrease, but it took about 4-5 hours for it to drop a percent. then it very slowly continued to drop....(i took it off the charger at about 6pm yesterday, it was about 85% at 1am). Now it's 10:38PM next day...and i'm at 24%. I've been using it quite a bit, except for when i was asleep between 5am and 1:30PM.
So, i guess that build.prop edit helped my battery life...quite a bit. I'll give it a few more days and see if it really is a noticeable difference.
EDIT: Looked at the battery stats. 53% - screen. 28% - google maps. I used gps navigation for about an hour today, so that seems about right. Everything else is 4% or less....so that looks pretty good.
Think I found a Bug
When I was trying to add a WiFi network; I tried to save the credentials to log into the network(Network name and Password). When I tried to save it, Settings crashed... So potential bug is Potential
Some Info:
The SSID was Hidden
The WiFi use WPA2
The phone had no OC
What I did to Remedy
Tried reinstalling the ROM by doing a complete wipe 3 times
Solution so far
Got it to work using the Google WiFi Password backup
This ROM is quite AWESOME!!! Now, for the issues at hand:
1.) The most recent GApps, 20120429, won't work...it simply won't open. Upon further checking on the RootzWiki article and trying to use that link, it seems that the file itself may be a hot mess. If that's the case, hopefully an update or at least a repost will be around soon. Worse yet, previous GApps packages won't work either.
2.) Is it possible to change the ringtone settings? I tried, and the very INSTANT I selected something different, the phone rebooted.
Don't have ICS yet so that feature isn't in my froyo browser . Baww!
Ya, I looked at that. I even tried to change to MTP or PTP to try it (won't stick). I get "Unfortunately, System UI has stopped". From the looks of things, I may just need to fresh install...
Ok, I flashed 10G, no wifi. I flashed Drew's kernel, entire wallpaper gone, and icons that are supposed to be blue is yellow. Even the bootanimation. Maybe a download error so I'm going to retry when I get off of work. I'm a workaholic. :cool:
EDIT: Reflash with FULL wipe, still no wifi. Maybe I have bad luck. :\
EDIT 2: Reflash with no Drew kernel, wifi works, but no wallpapers, and blue icons yellow. Bug in the ROM?
It is possible, I do it all the time. Gapps works fine too with the exception of the ICS voice search.
Sent from Optimus S running Kraven's CM9. Disclaimer: unless expressly started otherwise my posts are not meant as offense, I'm simply very, very blunt.
What mirror are you using (and anyway, what part of "No mirrors" do you not understand?). If you're using the link in the OP, that's not a mirror. They talk about how to get the download to work a lot in the previous pages.
I'm on cm7 so I don't have the options they have to fix, and yes excuse me the OP..
Here is my two sense and reports for MMS and SMS..
SMS (Texts) works fine, as does 3G connections. There is one "Sprint" APN missing from the ROM.. you may need to create that (see the OP) I think there is a data "fix" that messes with the APN's there..
MMS's - I am able to send MMS, but when I try to click on a MMS or Messaging Thread with an attachment attached to it, it says "Sorry! com.android.messaging has stopped responding" or something like that - none the less, it FC's... Sending works fine though.. Yes, I cleared Boot, Cache, Data, and System before flashing the Alpha10 version F ROM..
There is my two sense on messaging currently.
Have a great day..
-Pat. Akridge
gugino
