[ROM]COLD AS ICE-CM9+Paranoid Android LS670 11/20 ZVD basesband Alpha19
Re: [ROM]COLD AS ICE-CM9 Sprint LS670 6/3 ZVD basesband Alpha11
I requested it a few days ago to reopen. Thanks Cory. 15D is public on my goo.im account, just couldn't edit this yet.
I'm working with tdm now and support quattrimus LS670. That one will get differentials. I'll still push out my cai version with small patches and test kernels.
Kraven, I downloaded your 15D and tried to flash but it gives me this error
assert failed: getprop("ro.product.device") == "thunderc_LS670" || (says it twice)
Error in the zip (Status 7)
Installation aborted.
Am I doing something wrong?
What recovery?
Reactions: tlrsax54
What recovery are you using? If you are using drew's Cannibal Recovery, update to the latest version and it will flash it fine.
I've always used Xionia CWMA, it worked on previous CAI builds (and quat), this is the first time I've got this error before :-[ maybe I messed something up...
I've always used Xionia CWMA, it worked on previous CAI builds, this is the first time I've got this error before :-[ maybe I messed something up...
Yes, the asserts have changed in this ROM and @tdm rom, and working with drew to get them all to work with the new open source scripting and open recovery scripting. Get Cannibal Open Touch 1.1. Do it now. :D
Reactions: tlrsax54
it has to do with a line in the build.prop which the recovery checks to make sure you are flashing a compatible ROM. something got changed, and now the recovery and CAI's build.prop dont play well. Drew recovery fixes this. I HIGHLY recommend using COT by Team Hydro. it does everything Xionia does and is actively dev'd.
Reactions: tlrsax54
Re: [ROM]COLD AS ICE-CM9 Sprint LS670 6/20 ZVD basesband Alpha15
Alright alright...guess it's time to upgrade my recovery...haven't done that in forEVER haha!
Thanks for the info guys :)
Edit : That was quick and painless...works now :)
I'll make sure it's compatible with Xionia. Thanks for pointing that out.
Bit of a bummer with post 31 by Qualcomm. https://developer.qualcomm.com/forum/qdevnet-forums/multimedia-optimization-qdsp/13248
qualcomm is basically saying they wont write driver or libs for the msm7x27 chipset right?
the only way we will ever get hw encoding now is if someone writes the whole driver set by hand i assume?
Saw that in the Android forums on XDA earlier. Completely dashed my hopes of ever getting full hardware accelerated video.
A sad decision on Qualcomm's part. All we really need is hardware accelerated video playback and recording, We really don't even need the HD support as long as SD works >_< (Thanks Qualcomm, would've loved to watch Netflix on my phone running ICS without needing to downgrade to GB just to get it... What? I'm hooked on ICS.. ^_^; )
So, is this to say that Quattrimus is where it's at from now on?
Quick note: dirty flash of 15d doesn't seem to fix the mms issue.
Sent from CAI alpha 14 using Android Central
As of right now, more functions work for me in CAI a15d than in quattrumus b1p3, and it feels faster and smoother with the linaro optimization. That may change in the future.
Techview
