[ROM]COLD AS ICE-CM9+Paranoid Android LS670 11/20 ZVD basesband Alpha19
Re: [ROM]COLD AS ICE-CM9 Sprint LS670 6/20 ZVD basesband Alpha15
ROM: COLD AS ICE-CM9 Alpha 15d
Kernel: HydroKernel 2.6.35.7 v01pre4 (yes it's the ICS version)
Recovery: Cannibal v1.1
Phone: Optimus S LS670 (Sprint) ZVD
Bug: Wallpaper is just a bunch of pixelated trash. Colors are off, blues are yellow, reds are blues, etc.
Long pressing and trying to take a screenshot just puts everything back to how it's supposed to look :confused: This was a clean install.
Btw I had the same problem with both releases in Alpha 11. It's a real eye sore. Any ideas?
Your Kernel maybe, try sticking with the original when you flash the rom
Reactions: Partof300
Posts by drew, the hydrokernel developer tell you to stick with the ICS kernels that come in the ROMS, and not to use that kernel.
http://forums.androidcentral.com/lg...okernel-v01pre4-oc-enabled-5.html#post1866862
Oh sweet jesus I can see again!!!! :D
Just a heads to kraven to change the recommended kernels in the op.
Thanks guys!
Using ICS CAI test16 kernel.
Re: [ROM]COLD AS ICE-CM9 Sprint LS670 6/3 ZVD basesband Alpha11
Kraven, I downloaded your 15D and tried to flash but it gives me this error
assert failed: getprop("ro.product.device") == "thunderc_LS670" || (says it twice)
Error in the zip (Status 7)
Installation aborted.
Am I doing something wrong?
Have the same problem here. Xionia CWMA.
Reactions: illinoissparks18
You need to upgrade to the new Cannibal Open Touch recovery where the asserts were fixed. There is one in the Optimus S forum and one in the Optimus V forum.
I'm uploading alpha15e to fix xionia installs. Otherwise replace this line in the alpha15D zip file. Navigate to the file updater-script located at
META-INF\com\google\android\
edit the file
then replace the first line with
Code:
assert(getprop("ro.product.device") == "thunderc" || getprop("ro.build.product") == "thunderc");
Save the file, and flash with signature verification off.
Otherwise wait till i upload alpha15E
TheKraven, is this going to work on VM? I downloaded the apha15d but wanted to make sure before I do something to my phone.
It did in the past, but I am on the S. Did you know that @thekraven has teamed with @tdm for the quattruimus ICS for the VM, VS and OS? You might be better served with that one since there is a VM version.
http://forums.androidcentral.com/op...acks/156426-rom-alpha-quattrimus-ics.html#anb
I tried that version but this one is much stabled. Last time I run it the only thing that did not work for me was wifi tethering and the problem that when I have the charger on the phone I could not shutdown the phone. I do not use wifi tethering that much so it is not a major concern for me.
The fix for the home / menu key swap will likely be needed, but if you ran it before, you know that. Try it and see, you can always restore a nand if not.
Someone said that the button fix does not work, but the ROM does work on the VM.
Still fine tuning my minty fresh clean install of a15d (read, tweak, reboot, check, repeat over and over), and it made me look at this, since it has been an issue to resolve.
zzzzzzzzzzzzzz
ZZZZZZZZZZZZZZZZZZZZZZZZZZZZ
:cool:
ignore me if this is the wrong place or it has been answered.
I flashed 15d via cannibal 1.1 yesterday. everything was awesome! Woke up today, and cant get a good sync status. As in, my data signal never goes blue. it is staying grey.
I have rebooted a few times. Turned wi-fi on and off. Turned Airplane mode on and off. Turned data on and off. All to no avail. Tried to find the right thing with dev tools. but, couldn't see what i was looking for.
If there is something I missed, can anyone point me towards the right place?
Other than that issue, this is great! haven't had the dreaded disappearing text issue! Which was the only problem i ever had with 11.
Thanks in Advance!
