[ROM]COLD AS ICE-CM9+Paranoid Android LS670 11/20 ZVD basesband Alpha19
Oops.
What I meant to ask was about getting a white screen in gmail. When I try to read a message the text of the email will appear for a second and then it turns white......nothing in the body of the email remains
Thanks in advance
Go to Settings --> Manage Apps --> gmail Force Close. I think that should work
Sent from my VM670 using Android Central Forums
Interesting...I personally never had a problem with offline charging.
Sent from a Purple LG-LS670 with CM9...the New Wolzard Phone...yes.
Re: [ROM]COLD AS ICE-CM9 Sprint LS670 6/26 ZVD basesband Alpha16
Wow holy crap.... I've been gone for a bit. Been running A11 for awhile now. Time to update. :D
Wondering, has anyone else had trouble with going for your phone you just used to find it has completely shut off and won't power on until you pull the battery? I find myself doing that every other day. Wonder if that's something that's been addressed?
I think that is the deep sleep issue, and yes it has or is being addressed
ok, good to hear. Just booted up A16. love the new boot screen, went perfectly to "Promises" by Nero that was playing on a tv commercial. Sorry just had to share. Still upgrading now. Thanks for the work though Kraven!
well alpha 16 is pretty much as advertised. clock lag still exists (shocker), offline charging functions as described (kind of annoying to have to hold the power button down all that time but oh well)..............hmm, i haven't done much else yet besides restoring my apps and changing some settings, so i'll post back if I run into any new bugs.
Reactions: Thraeryn
Make some calls? I'm curious as to how the new audio files hold up. I'm sticking with 15f for a while because I know Bluetooth still works. :-\
I downloaded alpha 16 but it will not load past the cid loading screen. I wiped everything and can't seem to get it to work, anyone else having issues? I'm going to try and re-download it in a few to make sure it wassent a bad copy
Sent from my LG-LS670 using Tapatalk 2
Same thing for me. VM670, ZV9 baseband. Checked MD5. Did manual wipes of everything, then ran Prep for new ROM. Flashed A16, then small gapps. Can not get past Cid.
Did you do the procedure three times? I always used LeslieAnn preparation for an update or new ROM and never had an issue like that. I am also using the new cannibal recovery which should help.
See post 2 for new audio drivers with speaker phone fix from lgics team. It should work for other builds too.
Reactions: prowlingfox
Cid the bootanimation or Cid the graphic? Try holding down power till you see the bootanimation. Or reboot unplugged.
Try formatting boot? or what recovery? The offline charging adds new files to that partition. I flashed over 15D ok with Cannibal 1.2 recovery. On a clean install, it flashed ok also with cannibal 1.2 recovery.
I wanted to report that MMS is not working on alpha15F with the stock sms app.
My device is VM670.
Thanks for an awesome rom!
I just did a quick test on VM670 and MMS works on my phone without changing anything. I just have the latest ROM alpha16, Cannibal 1.2 VM fix, gapps 4/29.
Reactions: Thraeryn
So, you are saying that it's working on alpha16 of 15f?
Question did anybody found an application for wifi tethering? on alpha 16?
Speakerphone works, loud and clear. No issues switching back and forth between front speaker and rear speaker. Pretty awesome stuff.
MMS is working for me, clean install of a16. sending/receiving on wifi & 3g is all good.
ls670.
Reactions: Thraeryn
r3dpuk3
