[ROM]COLD AS ICE-CM9+Paranoid Android LS670 11/20 ZVD basesband Alpha19
Re: [ROM]COLD AS ICE-CM9 Sprint LS670 6/20 ZVD basesband Alpha15
I'm still can't get mms working on 15f. Anyone else have this problem?
Edit: after the third clean install it finally worked... weird.
I've re-installed twice and no luck yet. Are you formatting everything every time? And which gapps are you flashing? I just want to make sure I'm doing the same thing without any missteps. MMS and working voice search are the only things I'm missing, and voice search has a temp fix.
Thanks. Anyone with other suggestions, feel free to chime in.
This is what I did;
A full wipe(system, data, cache), wiped dalvik cache, flashed leslie anns prep for a new rom, flashed 15f, flashed kravens 4/29 gapps. Mms should be working, thekraven added mms.apk from11d and this apk does work, I've tried it on other versions and it works very well.
sent from my icy cold optimus using inverted T.T.2
This is what I did;
Yeah, still no luck. I switched to the Quattrimus ICS ROM for MMS, but the Wifi speeds are BRUTALLY slow so I came back. I did everything you did minus the new rom prep (I flashed Debug-FormatSYSTEM) and I flashed the full version of gapps as opposed to small. Do you think I should try installing just a new MMS apk? It's not make or break for me, but I know the wife appreciates being able to get pictures back from me and whatnot.
Suggestions? Thanks.
EDIT: Replaced stock MMS app with this one: http://forum.xda-developers.com/showthread.php?t=1667615. Looks better, works like a charm. Thanks for your patience.
Reactions: rebel69ization
I started out with a fresh install of Alpha 15C (private alpha), which didn't have the old audio files or the working MMS. I flashed the old audio files and a different MMS.apk and it's all working as 15D is supposed to.
Try this:
grab either Mms.apk from here and drop to C:\
[APP] CM9 Holo Dark MMS [5.31] - xda-developers
(I personally like the dark version)
then
(do not type # symbol)
Code:
adb remount
adb shell
# cd /system/app
# rm Mms.apk
# exit
adb push C:\Mms.apk /system/app
adb reboot recovery
wipe cache and reboot.
EDIT: Oh lol looks like you got it with basically the same method right before I posted this. I'll leave it here so it'll hopefully help others.
Please forgive me, I'm sure this has been answered but I can't find it.
In the OP it says this is working for the vm670 in the newest build. Do we still need to do the separate home key fix flash? Or does the link for vm that kraven posted fix that?
Again, I've not used this rom in quite a while.
I was wondering if people with deep sleep issues are having it because of stuff like lock screen weather or Widgets they are using, or would those cause it not to go to deep sleep?
Sent from my LG-LS670 using Tapatalk 2
I have them on and woke up yesterday after having the phone off the charger all night and still had 70% battery :-)
Sent from my LG-LS670 using Android Central Forums
OK but did the phone go into deep sleep or just the lowest CPU setting? Also how long does it take for the phone to enter deep sleep?
Yes 15d vm fix works
Change the m. in build prop to pm. and it will deep sleep
Reactions: Va1ha11a
I'm using the newest build with that already fixed. I was just curious
Not going into deep sleep has been an issue from day one. I am still testing one line in the build.prop that supposedly affects it, but the searched info about it on the net conflicts as to on or off is allows it.
I tested it off (0) yesterday, and got 1:52 minutes deep sleep, even overnight. I just changed the build.prop to on (1), cleared cache and dalvik, and will see whats up tomorrow morning.
Running 15f after a clean install, test16 kernel, CPU 320/787 on savagedzen governor. Since I flashed yesterday afternoon, my phone spent 52m19s in deep sleep, and 4h52m at 320 MHz.
The build.prop edit thekraven made doesn't seem to have changed much.
The only thing I've noticed that puts my phone into deep sleep reliably with any ICS rom is airplane mode, it works every single time. After I turn on airplane mode and let the phone sit for a bit it deep sleeps, and does so consistently. Otherwise I'm lucky if I get minutes of deep sleep out of hours of uptime. This is before and after the "pm" build.prop tweak. Mind you, this might only be because I'm using an OV, but I doubt that makes much of a difference.
Well scratch that last post I made. Mms worked for a little bit and now just doesn't work again. I haven't done anything differently since I was able to get it to work.
try my method at the top of this page...it might work, it might not...but that's how I got it working for me.
wilderjohn7
