[ROM]COLD AS ICE-CM9+Paranoid Android LS670 11/20 ZVD basesband Alpha19
Not too many updates as alpha4 was based on lupohirp Beta4 folders. Plus their fixes are not exactly public.
Re: [WIP][ROM]COLD AS ICE-CM9 Sprint LS670 2/20 ZVD basesband Alp
Is the new build waiting for the next big release by lupohirp?
I'm sorry, but I'm not quite clear. Which is the correct time? The SB Clock, or the Big Clock in the Center Clock?
The big clock in the center is right...I opened up the clock application. It reads correctly and my alarms go off on time, but often times the clock on the top right (smaller clock) sticks to whenever I last shut my screen off.
Another example; I see a lot of text messages that will say "Sent at 1:05 PM" but the small clock says it's only 1:00....kinda trippy lol.
Please help, kraven. I removed the persist...16bpp line in build.prop, successfully rebooted, and it ain't helping.
It is doing the "rays" thing with EVERYTHING. Please Take a look at my images.
Anything you can think of to fix this??
Can't get vids to play either...
Thnx for suggestions in advance...
Sent from my LG-LS670 running CyanogenMod 9 and Ice Cream Sandwich!
It could be the Surfaceflinger lib. I see some spots where gradient shading isn't working yet.
As for the vids, no fix yet
This is hilarious My mom has this phone... and usually keep her updated on this stuff one month later yall have CM9 hahaha just got cm9 for my Epic and my brother has yet to have cm9 for his evo. Too bad there isnt more working otherwise i could put it on. anyways someone have a how to downgrade to zvd? Shes on Hydro Rom beta 2...zvh a so forth what would be the proper way of doing this... flashing the update.zip for froyo? and then rerooting? Thanks:cool:
Just flash the official Sprint froyo update.zip once from Xionia recovery (turning off sig verification first), then boot into stock froyo (there will be a radio mismatch at this point). then turn off the phone, hold down power, down arrow, and home key to boot into stock 3e recovery. then flash update.zip again. This will flash the radio image. then you'll have to re-root and reinstall xionia using the optiauto-sfx, which you can get in here.
Where can one find the Sprint froyo update.zip?
Hey...
I couldn't get headset (ear buds) to work...
All I would get is this screech sound with static.
But, I fixed it!!
Go to DSP Manager > Headphone > Virtual Room Sound Effect and tick that box!!
Hit the Thanks button if it helped you...
Your rom and drew's kernel is everything I thought it would be. Great job again!
Sent from my PG86100
Anyone else having charging issues? Battery was on 40% when I went to bed, was plugged up all night, and its only on 88% now.
Just wondering if this is just me
Sent from my LG-LS670 using Tapatalk
Others have had issues, the main thing that helps is trying different chargers I believe. Not sure that there is a fix yet.
I actually have charging issues with CM7, and yes, different chargers and cords make all the difference in the world. The HTC cord I bought: useless. The LG cord that came with the phone: persnickety, only worthwhile sometimes.
Hands-down winner among all my cords for charging: the super-long cord I got with my 3rd-gen Kindle. Don't know why or how, but that cord is quality.
Try every microUSB cord you have in the house for ten minutes of low usage. Note the differences. Hopefully you'll report back with some positive results. :)
kimswid48
