Hey Kraven: Would you be able to add DTa2sd to this rom? I've been trying to do it myself but for some reason, after flashing the new boot.img, it doesn't boot at all.
Would love to see data2sd as well (been using it on CM7) but only after things have stabilized and all the major functions are working.....thanks for all your hard work kraven!
Good point lol. I've been trying to get it to work using the tutorials from DTApps2SD's Facebook page but I keep getting stuck at the manufacturer's logo, opening logs in Recovery shows it's working, but the system just doesn't seem to boot.
Mine says charging with usb when connected to the computer
and changes to charging when plugged to the wall.
try re downloading the latest and re flashing the rom
link2sd is working currently I know its not the same, but its better than nothing.
Thanks.
Sent from my LG-LS670 running CyanogenMod 7 and Gingerbread
I can't get ICS to charge! PLEASE HELP!!! I have double flashed and can't get it to work. Plz help.
This might sound trivial, but do you have a different usb cable? Mine was doing that too, turned out it was the cable. Worth a shot.
I need to fix this. It is now only working when I plug into the car. I double flashed already.
what exactly are "Cheatman" fixes?Here's a couple boot.img.
57 fixes multiple dhcpcd settings eth0 and wlan0. Wifi connects faster for me.
58 same but with Cheatman fixes.
service dhcpcd_wlan0 /system/bin/dhcpcd -ABLK wlan0
