[ROM]COLD AS ICE-CM9+Paranoid Android LS670 11/20 ZVD basesband Alpha19
Re: [WIP][ROM]COLD AS ICE-CM9 for Sprint LS670 ZVD basesband Alp
do we still need the mic fix.zip for the beta 2 build? Wow this ICS is taking over our Optimus! YES
Home key works without the mic+fix, so I am testing and guessing no.
Reactions: aaronrw
Data is STILL not working for me. I don't understand what i'm doing wrong.
Alpha 2.
my home key is gone using alpha2 ?
EDIT: using Trebuchet it's fine. Great build. Drews kernel is AMAZING so far! My optimus has gained calories due to ALL this CM9 ICS goodness.
"LatinIME.apk is large ~10 MB, so look on the market for a mdpi on if you need room. "
could you please elaborate on this please, Kraven?
Re: [WIP][ROM]COLD AS ICE-CM9 for Sprint LS670 ZVD basesband on
Here is alpha2.
  • Lots of room made in this build
  • ~80 MB and you can delete Trebuchet.apk and save about 7 MB more if you like the Apex launcher included.
  • Youtube kinda works now, getting closer.
  • You will still need to flash Drew's new ICS kernel. This still has the 8.1 GK one.
  • Latest CM9 sync.
  • Sync with Beta 4 of P500 changes.
  • Using the IHO sprint apns-conf.xml. So test mms.
  • LatinIME.apk is large ~10 MB, so look on the market for a mdpi on if you need room.
  • alpha2b-thunderc-cm9.thekraven-signed.zip
  • md5 135050a97ec69576ba256f5ae1a7f07c
Dude, I freaking love you and drew now...
ALL data is dropping for me on alpha2 build. WIFI won't stick. 3g is gone. But smooth build
btw kraven went up to third in thanks ;)
just saying
I am also experiencing no data and wifi is having difficulties using alpha2. switched back to alpha1
I did a clean flash to alpha2
when i pressed setup wizard, it wouldnt let me sign up with my google account, it said i had no connection
it gave me two options right on boot, i pressed com.android.provision.defaultactivity
the wifi and data still didnt work
Well I only had data for about 5 minutes on alpha 1....so....yeah. I'm really frustrated....going back to CM7 IHO
Same here, no wifi/data on alpha 2. Not letting me sign in.
Phone getting heated up and rebooting :( Any preferred OC you guys following on iScream kernel?
KsmithinNY started a thread a LONG while ago about recommended setcpu rules. in the midst of flashing alpha2, than I'll look for a link.
+1
EDIT: Went back to A1. Flashed Drew's new kernel. now, when I try to turn on wifi, it flips on and than immediatly flips off (I mean the switch flips itself back into the off position. ) I'll post a vid if necessary.
OK I did fresh install of 2 and immediately rebooted. My wifi has been working for 8 hours and 3g is pretty constant when I check it. My only problem is no picturemail or camera. The kraven is getting close to perfection.....:cool:
Sent from my LG-LS670 using Tapatalk
+1
I had this exact issue with alpha1. I just rebooted without signing in. It worked but I still went to 2
I was also unable to get data or wifi to work on alpha 2. I tried it without drew's kernel and with. I tried rebooting, airplane mode on /off and toggling data as well. It's as smooth as butter though. Kraven and Drew are my heroes = D
Also after flashing Drew's kernel I couldn't get airplane mode to stay on.
mrtalha
