[ROM]COLD AS ICE-CM9+Paranoid Android LS670 11/20 ZVD basesband Alpha19
Re: [WIP][ROM]COLD AS ICE-CM9 Sprint LS670 2/20 ZVD basesband Alp
Does it work with MVH baseband? And which version do I install.
Your actually downgrading
Didn't seen to notice that. Well I downgraded and now I am running ICS. The only bad thing is that the camera doesn't work. Oh well. Don't really need it anyway.
Found a zip that allows my phone to run roms regardless of baseband.
Google sarcastic_android_nerdz.zip
Also, would like to donate one hundred millyun internets to thekraven for his hard work.
Edited... responded to the wrong post lol
Well...technically your phone should be able to anyways :P just with a few problems...
Flashed cm9.67.v8 to try to fix mms - no avail.
Anyone know how (if at all) to get MMS working? Skimmed through the thread and flashed mentioned .zip as per Kraven's suggestion.
Oddly somehow i managed to receive a mms but it would never allow me to download it. Is this the problem people are reporting or is it just simply not working?
Id love to get it working as i have people all the time sending me things. ;P
It shows the MMS on my phone, but I can't download it either.
could u get a link? I googled I could not find
Just got it installed, so far so good.
I can live without the camera for now
though gallery is not working
3g seems kind of slow now
download speed- 140 kbps
upload -278 kbps
any ideas on how to fix that
PRL maybe wrong?
I'm dieing to try this. I might have to hold out till alpha 5. I'm waiting for working wifi ,3g camera and video. And texting with mms . Without getting messages late and all at once. The kraven and drew you guys do great work. And when the ROM I'd a little more stable for Me to switch to I would like to donate $15.00 a piece to you two. I was going to say 25 but I forgot both of you guys were working on it . Keep up the great work you guys
My PRL IS 1115.Is that bad?
11115 is the business prl that lets you roam on other networks. But don't overdo it..
Is there a newer better PRL? Should I flash back to rooted stock ZVD and try to update my PRL? Thanks for responding to me thekraven. I have been running your CM7 for so long I don't know what is needed and what isn't. I love your work and can't wait to see this hit the beta phase. Lupo has camera working with no preview and has made some progress on stability with his version. I hope his stuff helps you. Good luck with it. It looks awesome so far. I did a backup last time I flashed Alpha 4b and can jump back and forth pretty easily. I had dat working but didn't bother to try wifi because of having to mess with so much. Thanks again.
Well, I am now very happy with the latest version of thekraven's CM7 and have an awesome setup to use until this is in the beta phases or at least gets a bit more stable. Great work man. Your work is the best I have ever used.:cool:
wilderjohn7
