[ROM]COLD AS ICE-CM9+Paranoid Android LS670 11/20 ZVD basesband Alpha19
Re: [WIP][ROM]COLD AS ICE-CM9 Sprint LS670 3/20 ZVD basesband Alp
Where do I get that fix?
booting up alpha 6 as we speek. Thanks.
Also in same post just above with A6 link from kraven.
from my LG-LS670 w thekraven CM9/ICS & Tapatalk
Hm. I can certainly see my phone trying to get the data, calling out to wherever it needs to; it's just not working. handcent is giving it its best shot, at least. :P
make sure your on wifi.
Data is working with blue bars after the toggle dance. Will report back later.
Hye, can anyone send me a link to a wifi ther app that will work with this? They have all been removed from the market evidently exept for Foxfi and it wont work for me.
i see where native wifi tethering is turned off in the frameworks, so should be an easy fix, just waiting for more fixes before a new build.
Try wifi tether app, choose optimus S profile, check clamping, and might have to change setup-method from auto, and turn on wifi-encryption
USb tethering should be working, but i never could get it working with windows7 with cm7. But worked fine with tethering apps.
I tried all of this and still no dice. It don't work with CM7 either. The native tether works great on CM7 but not on this. I need one of them to work or I can't run this daily. Thanks dude.
Nope, not on CM7 or CM9. Will not show up but it says it is working properly. The native tether app in CM7 works great but other apps won't.
Are you guys all able to save images/download files successfully from the browser?
I dunno what to tell you, android-wifi-tether worked for me in CM7 before built-in started to do so, and is the only one that works on CM9 via my experience. It also downloads itself to my phone from market account, so its still on there
Edit for pressing post too soon
alpha6 randomly crash-reboots more than alpha5v12 did, and when it happens I almost always have to pull my battery then power up to get an ACTUAL boot instead of a hanging-for-five-minutes-on-the-bootscreen-with-no-signs-of-stopping attempt. I'm not sure what's responsible.
No crashes of any kind here. Back on A6 now. Still running strong and stable for me. Just chasing apps sucking battery. :(
from LG-LS670 w thekraven CM9/ICS & Tapatalk
I am also in both regular browser and opera mobile.
battery life seems to be improving with more use. not a single crash or fc only issues I'm having is clock freezing caused alarm not to go off this morning
try this one, it's an older version of wireless tether but it's working for me as i type this.
wireless_tether_2_0_7.apk
I've experienced the same once on a complete fresh install, full wipe on alpha 6.
I downloaded it and installed it but when I turn it on my tablet or my PC either one wont pick it up. It says it is working but I can't get anything to find it.
Master zx
