[ROM]COLD AS ICE-CM9+Paranoid Android LS670 11/20 ZVD basesband Alpha19
Just curious but what's with the banding on bg images and such?
Re: [WIP][ROM]COLD AS ICE-CM9 Sprint LS670 3/20 ZVD basesband Alp
Hmmmm. That's weird.
I know especially since the native app works fine on CM7 but is turned of on CM9 by default.
The stock wallpapers? Or any wallpapers? I think lupohirp got it fixed in his new build, hopefully he pushes his fixes.
I also noticed that on CM9 my phone shows that it is plugged in but never actually charges when I have it plugged into mt Tablet. It charges really well on CM7 plugged in that way.
fyi. keyboard from a5 works fine. replace the current one with it then reboot.
Any atm. I know its not anything major atm. I got them to look somewhat better using quickpic
It seems all gradiants show banding. You can see it in the background of the weather application. I'm guessing it's not doing any dithering, even though the preference is set. Hopefully lupohirp gets it figured out and published :-).
Thank you so much for your work on this, thekraven. Since I hardly use MMS or my camera, this is my daily ROM. I'm looking forward to improvements in those areas, though! I like to use Google Goggles occasionally.
I'm using this as my daily as well. Only nandroiding back to cm7 to test the themes I'm working on :D
bought an otter box case for this from sprint the guy accidentally pushed one of the buttons and lock screen came on realized it wasn't stock asked what rom I was running when I told his cm9 ics he told me I was a lying cuz this phone isn't powerful enough for ics had to prove him wrong. he couldn't believe it even after he saw the Android version kept saying its not possible lol.
Lupo has his new development thread up and running. He is trying to get the CM team to pick up his ROM. If they do development will take off like a bat.
[Unofficial][ICS 4.0.3]CyanogenMod 9-KANG [LGP500] - xda-developers Please remember, this thread is for serious bug reports only. No spamming allowed in this thread. It needs to remain professional looking in order to attract the attention of the CM team. There are links in the post to other threads where you may make comments and suggestions, but please be respectful of Lupo's request. Thanks.
I know not to spam dev threads.
Has anybody found a lack of space with a6? I can't post a screenshot right now
Lack of space would probably be GApps, You could try a SD-EXT mod if you need more space though. Also I noticed that Alpha 6 doesn't seem to have Offline Charging working. I plugged it in last night while the phone was powered off and it booted rather than going into Offline Charging mode.
Yeah, duh. :D. Two OS jumps will do that. :) Just have to run bare minimum user apps.
from LG-LS670 w thekraven CM9/ICS & Tapatalk
So i guess the annoying color banding is fixed in lupohirp's newest release? that's super cool.
If MMS was working I would probably use CM9 as a mostly-daily driver, so i'm definitely looking forward to more fixes
You seem to misunderstand me. In the storage dialogue under settings, I'm told I have 95 mbs of space taken and 16 free, and than it says the total is 165 mb.
Yes and no.
Yes in the fact that CM9 leaves much less internal space available than CM7 was what my response was.
No in the fact that I understand what you are saying does not make sense. Add to that the space readings in TiBu are different as well.
There is something taking space that we are missing, I suspect. Cache or dahlvik maybe?
I tried booting into recovery and wiping cache and than rebooted and that solved nothing. Lemme try dalvik
