[ROM]COLD AS ICE-CM9+Paranoid Android LS670 11/20 ZVD basesband Alpha19
Re: [WIP][ROM]COLD AS ICE-CM9 Sprint LS670 4/5 ZVD basesband Alph
Also my phone still doesn't show that it's charging. None of the usually animations are animating. Nothing states that the charger is plugged in...
It's charging for me (or at least all indications are that it's charging), both plugged into the wall charger or the computer.
Will I still be able to restore backup and get service
You will have to restore to ZVD radio. nandroid backups do not backup radio, so you cannot just restore backup.
The only way to change the radio is to flash update.zip from Sprint. Here is one thread: http://forums.androidcentral.com/lg...sprint-zvd-froyo-downgrade-now-available.html I expect that flashing it from ZVJ will work as well as from ZVH, but I am having trouble finding confirmation so no guarantees.
Note: you need stock recovery for this update.zip!
Michal
damn has it really been this long? I just now changed the rom from your CM7 11/20 build :eek:
Though I use the camera a lot with this phone, I can deal with it. Love the new, everything, so far. Great work again Kraven. :D
(installed flawlessly for me even after forgetting how to do it for a few months)
Look forward to the camera fix if that ever happens
Lol:D:D:D
Sent from futuristic optimus s
Well it would seem that he's working on the camera, his git history recently shows commits for camera (not sure which repo I should be looking at for history, because it just redirects me to his profile page instead of a branch index)
Try these tips . unplugged, Hold down the home key, volume down button and power button. Keep those down, then plug it in, and see if you get to recovery. Off line charging is still not working. But on mine, it's always charged even from the dead.
2nd, is to connect to a computer and use adb commands. This depends on how far along in the boot process you get.
adb remount
adb reboot recovery
or
adb shell
reboot recovery
The zvj based kernels have better drivers for charging. They use a more universal google code than LG specific now.
Ok so I went ahead and reinstalled your rom again, only to find that my phone was still getting no charge. This made me think that maybe the usb on my phone was broken. So I thought a while and came up with the idea to leave it plugged in whilst in Recovery Mode. To make sure it was a controlled environment I made sure the phone or plug didn't move at all during this. So I had 8% at 10am, rebooted into recovery let it charge to 10:34; rebooted and upon CM9 starting up my battery was now at 22%.
So this proves that my USB plug is fine, which relaxes me a lot. ;) This obviously is some kind of bug. What are your thoughts? I'm going to try Alpha 8 and let you know what happens.
As annoying as this was, I actually really like this kind of problem solving, feel like I've made a contribution. :)
^^ maybe try doing a reinstall of everything? (again). I cleared cache, then formatted boot, cache, system and data. installed from zip the A9 build and gapps.
Everything but the camera works great for me after using for a day. Accurate " time on battery" stats, charging icon and notifications work, 3G data and wifi work, mms with stock app, phone calls, picture messaging and youtube all work flawlessly. power button works after the hotfix.
Must just be my luck :p
if you install hydro kernel, the camera works too. the ONLY thing that doesnt work is BT audio and camera previews/camcorder.
That's bluetooth audio right? if so, I don't use it anyway.
I will look into the kernel then.... thanks.
I randomly stopped getting text's for two days and i just flashed Drews new ICS kernal and all of the sudden I got all the texts form the past two days? lol
I had that happen to me once before too using LeWa ROM.....not sure what causes this...
Yea I could try that again. Currently in Recovery as that's how I've resorted to charging my phone. Luckily I have Google Voice so I don't necessarily need my phone on :)
r3dpuk3
