[ROM]COLD AS ICE-CM9+Paranoid Android LS670 11/20 ZVD basesband Alpha19
I'm using A9 and the camera works. You just can't see what you're doing before you take the picture.
My phone's being weird then, my camera app just freezes.
Edit: just got the "unfortunately, camera has stopped." Error while editing this post to fix that spelling error.
Re: [WIP][ROM]COLD AS ICE-CM9 Sprint LS670 4/5 ZVD basesband Alph
My camera just FC's as well. Its not just you. IDK how these guys got camera to work with the new adreno libs.....
I forgot this in my other post but Kraven: Alpha 9 has a weird bug for me, When I get a notification it routes all audio to the phone speaker then back (if I'm using headphones) whereas in Alpha 8 and below if I got a notification it wouldn't interrupt my music and the notification sound would come over both headphones and internal speaker (but the music wouldn't be routed to the speaker like it is now).
It's weird.
If I'm not being clear I mean
Alpha 9: (Listening to Music then receiving notification while playing)
during the time the notification plays, the headphones shut off and the music plays through the internal speaker, after the notification it switches back to the headphones.
Alpha 8:
EDIT: Ignore that.. It does it in Alpha 8 too.. I guess I didn't notice it because half the time I have it on Vibrate only. (Goes back to Alpha 9 and keeps it on Vibrate for Notifications.)
I am also on thekravens cm9 and my camera force closes too, also seeker phone does not work properly im not sure if that was reported yet. . i did not test the kernel from drew yet.
Not trying to get off topic , i know you can install different kernal on roms aslong as they are compatible. but if i flash drews new ics kernel and then thekraven has cm9 alph 10/Beta 1 come out and i flash that. dirty flash the rom and not clena flash . things may not work propley if the kravens rom fixes were made to work with his rom. So if a new rom build comes out i would be better doing a clean flash and wipe everything. if im going to mess with different kernels. I figure the answer is yes, but just want to ask .. sorry for any typeos im on luch at work
ROM flashes will replace any kernels you have previously flashed, period. You'll need to re-flash the kernel every time.
In general, a clean wipe and flash is a good idea even when upgrading ROMs.
Also is anyone's phone not charging? I plug my phone in to charge and it doesn't detect the charger, but after an hour or so the battery updates its charge percentage.
Right now my phone is dead. When I plug the charger in it tries to start up, but shuts off during the Cyanogenmod loading screen and restarts. This repeats for an hour or so and eventually it starts up. Then it repeats that process, but this time shutting off after the rom is loaded.
Any ideas on how to fix this? I know it isn't my charger or plug on my phone since it does charge after a long while.
Thanks for the response :D and ok. I'll stay on CM7 for now.
Just flashed drews ics kernel and now the camera takes pictures without crashing. Note the first time trying to take a pic cam made a noise like it was focusing but then did not take a picture. I then closed the app and opened it about twice and then could take pics no problem still no on screen display but hope this helps some.
Installed hydro kernel and it works!!still no preview :sly::( better than nothing!
Hey guys phone won't start now. Doesn't get past the LG screen. Trying to go into recovery mode only sends me to a black screen. Any ideas on how to recover?
Thanks! :)
Using Alpha 9 with iScream Kernel 2.6.35.7 v01
Thanks! :)
we are gonna need a little more info. what happened before it stopped booting?
phones dont usually just stop booting.
Well the only other problems I noticed was that my phone would not charge. I could plug it in and the phone would not detect the charger. Eventually the phone died. When I plug the charger in the phone tries to boot but would get no farther than the CM9 loading screen. Would just shut off, restart, and repeat. Now it doesn't get passed the LG screen. I didn't mess with the performance options at all.
Any thing else I should add?
im betting its a bad charger. most likely its getting an inital charge to get it to the LG screen, then not having enough in the battery to boot the phone. its caught in a dead batt boot loop.
try a new charger first. borrow one from someone.
Yea I already tried several different chargers and I had the same problem with all of them. Ended up having to charge my battery in another Optimus :p
I had a broken usb/charger port on my first opti. I flashed back to stock and returned it to the sprint store.
Curiosity (and boredom) finally got the better of me so I finally flashed this today (Alpha 9). Awesome work! I've been using http://forums.androidcentral.com/lg-optimus-s-rooting-roms-hacks/60353-dead-rom-scott-pilgrim-rom-cm7-gingerbread-zefie-edition.html as my daily for nearly a year, so this is going to be a huge step forward, once the bugs get worked out.
[Potential Fix] I had the charging issue too. It seemed to work correctly after I flashed Drew's ICS HydroKernel, so either the kernel or the reboot fixed it.
[Issue] I nanded, wiped everything, and restored a backup of my old ROM so I could back up some app data on Titanium Backup, but when I tried to restore the nand for this one (after wiping everything again), I got an MD5 sum mismatch - so it won't let me restore.
Is there anything I can do to bring it back or am I stuck starting starting over?
(I was able to restore the old CM7 ROM again, so it's more of just an inconvenience than anything else)
Thanks for all your great work and I'm looking forward to seeing how this progresses!
That's what I was thinking too, but how would a broken usb port prevent my phone from booting and from going into recovery mode? If it was something that simple I would probably have already replaced it by now :cool:
Try these tips . unplugged, Hold down the home key, volume down button and power button. Keep those down, then plug it in, and see if you get to recovery. Off line charging is still not working. But on mine, it's always charged even from the dead.
2nd, is to connect to a computer and use adb commands. This depends on how far along in the boot process you get.
adb remount
adb reboot recovery
or
adb shell
reboot recovery
The zvj based kernels have better drivers for charging. They use a more universal google code than LG specific now.
Reactions: Partof300
HOLY MOTHER OF ALL THAT IS HOLY.
Basically means that worked. My phone is on now and it can continue to be sexy.
Also when I got into Recovery mode I flashed HydroKernel v01pre2, because I just felt like I should do something more.
Anyways, THANK YOU! :D I'll be sure to report any other bugs I may have. This knowledge may come in handy in the future.
Also my phone still doesn't show that it's charging. None of the usually animations are animating. Nothing states that the charger is plugged in...
Five
