[ROM]COLD AS ICE-CM9+Paranoid Android LS670 11/20 ZVD basesband Alpha19
Alpha 10 is da bomb with the combo of kravens test kernel based off of drews its works pretty and for those who want alpha 10 he's having it be tested (I think) he will pm u when he's ready
Sent from futuristic optimus s
Re: [WIP][ROM]COLD AS ICE-CM9 Sprint LS670 4/5 ZVD basesband Alph
In "Settings-->Backup & reset" is Backup account. Is anyone elses greyed out? I should note that this appears to be a gapps problem, so sayeth the xda...
no, using the latest gapps 4-29
Ya, I just flashed over 4/22 with 4/29 and it seems to have been fixed.
Here's the changelogs for gapps. I wasn't sure of what changed till now. http://wiki.rootzwiki.com/Google_Apps
You could always grab the official gapps, about 50 MB, but it will only install what is needed based on your phone. The majority of the files are for front camera facelock, and I take those out.
Your CM7 has 'ALWAYS' been by favorite rom until now and it has changed. It's your CM9 now.
Thanks for the work Kraven.
hey ok guys i have a question i cant do anything with my voice search can you help me out with this is it something i am doing wrong or is it just not ready yet?
Which version of the optimus are you using?
edit: also, check to be sure that Voice Search is installed. I don't think it was on mine....
I run flash 10.2 just perfectly.
Which build do you use? I found an old 10.2 build that made my phone unusable. Didn't work either.
Alright Kraven, it was hard, but I ignored the PM late last night to get sleep instead. But now here I am. Initial impressions, camera works sweet (thank god the annoying shudder sound was changed in ics). Using your test kernel, which I can't tell a huge difference right now, but things are quite smooth. Not overclocked at all either. Data still solid. FWIW, I'm running a data2ext script and that's working swell. I didn't move my dalvik at all, but seems fine without doing that so far. One thing I notice is the phone speakerphone volume is still crazy quiet - but that's pretty minor. Flashed 4/22 gapps, and the gmail scroll problem isn't here... yet. I'll keep testing things throughout the day, but so far this seems like the best build to date.
Try uninstalling via titanium backup, then install voice search in play
Yeah mine isn't working either, I'm on an optimus s and I have voice search dled. I think my mic in general isn't working, when it comes up its just a Grey circle.
If that were true, you wouldn't be able to make any phone calls. Get titanium root from the market, free version, and uninstall voice search. Then install again from market. Works for me now.
Edit: One other thing to quickly add - I tried a couple barcode scanners from the market and they don't work. Even though camera preview works fine (and taking pictures), hovering over a qr code to scan it doesn't work.
lg ls670 gotta say i do love the alpha 9 is there anyway to get a pm for alpha 10 i would love to start learning how to write the code and things.
it worls just not on my keyboard to convert voice to text
Any way to get in on the semi closed release of alpha 10? I would love to test it out. Were slow today at work so may as well ask lol
Sent from my LS670 using Tapatalk 2
I haven't played with the default keyboard. I usually immediately install Swype, which has the VtoT button thru DragonGo. But my settings shows Google speech-to-text and Swype are both enabled for my keyboard(s?).
where can i get the swype keyboard at?
sukarisw09
