[ROM]COLD AS ICE-CM9+Paranoid Android LS670 11/20 ZVD basesband Alpha19
Re: [WIP][ROM]COLD AS ICE-CM9 Sprint LS670 4/5 ZVD basesband Alph
I still can't find this setting....what am I missing?
Settings, scroll waaaaaaaaaaaaaaay down under System { } Developer options, again scroll all the waaaaaaaaaaaaaay to the bottom.
With that, I am unsubscribing from this thread; I'll pop in once a week, but my comments will be posted in the PMs, not here in the juvie circus.
Hope thekraven decides to one where there is actually discussion on the Alpha ICE build, without it being 99% lol and hehehe, and waaaaaaaaaaaaaaay off topic. I don't have the time.
Well alright then.
We'll miss you.
And my first random reboot under alpha 10! Happened while using FB mobile site through stock browser. Not much to report; was overclocked to 787/320, don't think anything else intensive was running.
I hope that's not the case - I, and I'm sure many others, appreciate the feedback and information you post in this thread. I'm sure the "juvie circus" will die down soon enough. Alpha10 looks to be a major step forward, so some excitement is to be expected.
(Full disclosure: I was arrogantbastard before, but can't log back in under that name for some reason, so I had to create a new account :()
[a10 with newest test kernel and running a data2ext script]
Apologies I have been a little hit and miss keeping up with everything here lately, are you using the same data2ext script/instructions as cm7? Did you have to do anything special to get it working?
sorry for offtopicness but you were one of my favorite ales!
@theKraven I was wondering what you wanted to accomplish before this becomes a beta rom? Because it seems like it's almost complete with the camera preview
Working flawlessly on VM670 (alpha10) with the Hotfix provided.
I'm using this zip:
http://forums.androidcentral.com/lg...imus-s-roms-a2sd-replacement.html#post1671736
Flash rom and gapps, boot up, then go back and flash this zip.
It's more or less the same type of thing that a few members and I worked on figuring out back with CM7. I had a version I modified that doesn't work with CM9 anymore, but this slimmed down version does the trick. I'd suggest a gig ext partition, zero swap.
Figured I should quickly explain it. It basically creates a link that points the pone to look for the data partition on the ext partition.
Reactions: ShadowEO
idk, today's events really didn't sit well with me. I saw it linked in another forum too.
sorry if this has been mentioned before for me the talk button on side ends phone calls as well as locks/wakes up phone running a9 both stock kernel as well as Drews hk. this happening for others also?
It's only supposed to wake the phone, but not end call. It's mapped like that in CM7, since i can't get voice working there. Its in the generic.kl or thunderc_keypad.kl file.
Hey, I've been using alpha 9 as my daily driver for a few weeks now and have a couple of questions if someone wouldn't mind.
Does anyone know of a way to get visual voicemail to work? I've tried pulling it from other roms and installing it (both as a normal app and into system apps) but it doesn't work.
Is there a way to disable the data usage warning?
Still a GREAT rom though, can't wait for alpha 10 (although I will cause leaking stuff isn't cool)
Fyi, I found that someone posted the test build at Android Forums and asked them to remove the link.
My apologies on behalf of the OV community.
I did the same (I didn't want them to get in trouble) but anyway kraven I'm sorry for my actions
Sent from futuristic optimus s
byronsss
