[ROM]COLD AS ICE-CM9+Paranoid Android LS670 11/20 ZVD basesband Alpha19
Correction: it works with Play music, but not poweramp. Which is not a problem because poweramp has all the control you need anyway.
I think this is the correct operation with DSP manager, it's happened for me on every version, but I'm content enough with Play Music enough that it doesn't bother me that much.
Re: [WIP][ROM]COLD AS ICE-CM9 Sprint LS670 5/6 ZVD basesband Alph
Please, Please, Please, Please!!! Bring back the RenderFX widgets. Those are one of the few things that really made CM7 stand out from everything else.
im glade I mentioned I could not scan barcodes a few days ago. Cause kraven then made these patches and we get bar codes and video now. Thank you kraven flashing can fix 3 now and then getting video illusion . And will try net flix too. :) :)
We're still in alpha. By we, I mean the entire cm9 project. We just got theme chooser up and running (and not a theme in sight). Camera was just fixed. I would assume bluetooth would be a priority over renderfx.
You're the first person I've heard actually ask for it.
I understand, I just really like RenderFX, it really helps with night time viewing.
BTW, Thanks for all the hard work thats being put into CM9, It really is awesome.
I didn't even know of anyone who actually used that haha :P
Oh! I might have misrepresented myself! The only thing I've done was test for thekraven. I have absolutely no ties to this rom otherwise.
Alpha 10 camera fix 7:
  • added new permissions in ramdisk, stock test3 kernel again,
  • new OMX libs thanks to argen75,
  • preview in stock cam is not choppy now.
  • Still need videocam illusion for vid recording.
  • Hq youtube still laggy.
  • Test out video file playing.
  • wipe cache and flash in recovery cm9.a10.camerafix7.zip
Is it possible to get the default messaging app the option for a black theme like cm7 if not oh well I don't wanna put anymore stress on the kraven
After the CyanogenMod team gets the ICS/CM9 development done, I'm sure someone will do some themes like that; the theme engine for ICS was just added to the build a day or two back, there are no themes for it yet.
It would have to be a full system theme. Except for the 3rd party SMS apps, I have never seen a native CM7 SMS theme. Look at GoSMS or Handcent.
I have an ICS one that matches perfect in GoSMS.
It broke my wifi.
Flashed fix 7, wiped cache / dalvik, rebooted. Data is go, wifi is no. Rebooted to recovery, restored nand, flashed fix 7, wiped cache / dalvik, fixed permissions, rebooted. Wifi is off and you cannot turn on, even with the airplane toggle dance.
Restoring my nand now............ :D
Okay thanks for the response
It broke my wifi.
Hmmm...I just flashed fix 7 a little while ago and my wifi is working. It seems a little shifty though (wouldn't load a couple of web pages on the first try but did when refreshed).
Vibrations (custom patterns, to be specific) in stock messaging app aren't working. Using HK pre 04 and camera fix 3; haven't updated to most recent camera fix.
Just applied camerafix7 - the 2 or 3 QR codes I scanned with Barcode Scanner worked just fine. Camera preview is smooth as advertised, videocam works with Videocam Illusion. The patch didn't break anything for me, including Wifi, as far as I can tell.
I got the disappearing text in Gmail today, but it only happened once. I couldn't reproduce it.
3G seems weaker with this build than a9. By that I mean that when moving in and out of coverage (which I do a couple of times during my commute and every time I go in and out of the building I work in), it doesn't seem to re-acquire very well. I had to toggle data several times today in known coverage areas, whereas before I didn't have to.
I didn't see any supercharger script in the build.prop - should I give it a try?
Aw man...is everyone else's videocam illusion app still working after flashing fix 7?
Mine just goes to black screen then says it's not responding. Tried it 3 more times after clearing the app's cache and data, but it's still doing it.
^^ Nevermind, rebooting fixed it -_-
Edit: I'm also noticing wifi and 3G seem weaker in general, as a couple others have reported. I'm posting this from my phone and it's having a hell of a time connecting to the server.
I noticed during calls, the speaker phone does not work correctly. It has way too low volume on my Optimus S
alpha10 test3
I believe it's a CM9 issue. It routes the audio to the speakerphone but does not increase the volume.
In other news, I seem to run into a weird issue of losing 3G after using airplane mode. What i mean is that after I turn airplane mode back on, 3g icon shows, but never turns blue. A ping test fails, even after radio toggle. I have to reboot to get it back.
r3dpuk3
