[ROM]COLD AS ICE-CM9+Paranoid Android LS670 11/20 ZVD basesband Alpha19
Re: [WIP][ROM]COLD AS ICE-CM9 Sprint LS670 5/6 ZVD basesband Alph
Synced to latest CM9.. but I didn't see any notes of fixing bluetooth.
Probably don't need to ask since it seems like you are, but are you saying BT is a CM issue? I'm just wondering because it's basically the only bug standing between me and flashing this baby immediately (I use it everyday to chat in my car).
OK can you help me please I installed a10 test 3 and I still can send mms is there a fix for that
Handcent works just fine for me.
yeah sorry i had newbie moment my data wasnt turned on
hmmm.. question.
what are you guys doing to get more memory?
i only have 28 apps installed and im out of memory?
i have a bunch moved to sd and i have a cache cleaner...
So far so good. :D
A10 test 3, latest Gapps. FULL WIPE and fresh install.
Wifi and 3G connect no problem, speeds seem to be as expected.
No clock drift issues so far. Alarm went off as expected this morning.
No issues restoring apps from TiBu, no problems downloading/installing/updating anything from Play store.
Running at 787/245 on InteractiveX, everything is really smooth and snappy.
Love the new recent apps preview - although it does seem to stutter a little when scrolling side-to-side.
Haven't applied/tested camera/barcode fix yet so no comment there.
Battery seems to be draining quicker than usual. I'm already down to low 60's since leaving the house at 6:00 this morning. I'm still in the restoring apps/checking settings/general playing around stage so I'll hold judgment on that for a couple of days.
GMail sync/notification - wasn't happening. I checked accounts and sync settings and saw that Gmail was NOT checked by default. Will test later to see if correcting that fixed it for good.
Clearing Dalvik is a temporary fix, at best. If you're really wanting more apps and have already moved what you can to the sd card, you could try the "pm setInstallLocation 2" adb trick to get other apps to sd, or even install an apps2sd script that moves your entire data partition to an sd-ext parition on your card, giving you a ton more space. I've done the latter, and have 1 gig "internal" space (not really internal, but still shows as this).
As for latest test build, I screwed up flashing it and got it a boot loop, but all good now. Running quite stable, not a single reboot all day yesterday or the night before. I'll flash that latest camera patch to see how that works. Also, display clock is still lagging for me, even with disabling the 'back button to kill' option. I've seen here that the system clock is still accurate, though, so I'm hopefuly I can set up my Llama profiles again.
Edit: Just flashed camera patch. Yep, quite laggy in stock camera app. Barcodes will scan, however. This is very good. Haven't tried a 3rd party video app yet, but video option in stock camera app still crashes.
My first impressions with a10:
Fixed my wifi issues from a9. Link2SD seems to work a lot better now, I don't have to Quick Reboot to mount the sd-ext every time I restart the phone now. The barcode scanner is choppy but works, though I'm not having any choppiness issues with the regular camera as some have mentioned. Definitely a daily driver now.
Are you using Google goggles or the ZXing barcode scanner? I can't get Google Goggles to scan in continuous mode and ZXing never registers a barcode, it just keeps auto focusing.
Edit: ignore this for now, I'm an idiot, Tapatalk wasn't showing me all the pages.
Edit: after installing camera fix, barcode scanners work great, but their very very choppy lol.
Video capture working with Videocam Illusion and cam3 fix. So the biggest things still broken are Bluetooth audio and high-res video playback, right? That's pretty good progress!
(oh, and offline charging)
I'm getting a recurring problem on the A10 v3... Everytime i go into my wifi settings to "add" my wireless network i get an error message saying "unfortunately, settings has stopped" and it closes out. I've also reflashed this but i get the same error message each and everytime
Get a logcat to thekraven.
LG-LS670 w thekraven ICS ROM & Tapatalk
Yea I'll get that out when I get home. Anyone have issues where headphones are plugged in but dspmanager won't work with them. I can listen to music via headphones but dspmanager won't work
Oddity: Personalized ringtones work for some contacts, not others. Don't really know why. Might it have something to do with Voice?
DSP manager doesn't work for me either. It worked in a9.
Correction: it works with Play music, but not poweramp. Which is not a problem because poweramp has all the control you need anyway.
I noticed during calls, the speaker phone does not work correctly. It has way too low volume on my Optimus S
alpha10 test3
OkamiSeishin
