[ROM]GB 2.3.4 gingerbread-evo-deck [1.0][2.3.3 Stable][1.2c][2.3.4 Beta]
Hmm...what is your screen time out set at?
Sent from my evil hideout. MUWHAHAHAHA!!!!!!
When I had Vaelpak, it doesn't matter what the screen timeout is set at. When I am on the phone, no matter 1 minute or 10 minutes, it never goes to the lock screen. I just goes back to the dialer screen when I hang up the call.
Just annoying...
Sorry for the super delay guys on the report. I'm am flashing now....give me about an four and I'll let you guys know what is up. :-)
Just annoying...
I think it might be just an AOSP thing. I finally noticed what you were talking about. I feel ya on it being a slight annoyance, but definitely nothing that would turn me away from this ROM. :-)
Not reading through 25 pages of stuff on tapatalk to see if this has been talked about, sorry only on a lunch break, but after I sync my fb contacts and join them with the proper people. I normally turn my phone off once a day and when I reboot they are not sync or paired.
Anybody has a fix or suggestion?
Sent from my PC36100 using Tapatalk
Not trolling, just curious - what does this have over CM7? I'm running that right now and am open to switching, but not sure what this has that would make switching worthwhile.
For me, this is the first AOSP ROM I have EVER used where everything works. With CM7 I always had problems with GPS, MMS, or something not working. Maybe CM7 finally has everything working now, but this ROM beat them to the punch. I'm very pleased with this ROMs performance, functionality and stability without needing to make any further enhancements or flashing a different Kernel. Give it a whirl. I'm sure you'll find it very similar/familiar to CM7.
I just saw on Twitter that he just released 1.2x for us!!!!! Downloading now, charging phone, flashing when its done. :-) :-) :-)
I actually haven't run into that issue, that's quite odd. You might want to give the latest build a try, might fix the problem.
Is this good? I'm at 45% battery life and that's with moderate use.
Hey homies....peep this. ;-)
That leaves only two more letters before the end of the world :eek:
Just a question. After i flash the new deck zip can I delete the old ones.I will probably just store them on my pc.
Absolutely, you just need the zip for flashing the ROM.
Thanks,
Are you having any problems with x. I can't seem to get the app market to start. So far everything else works except for that.
Thanks,
I actually haven't had a chance to flash it yet. My phone is currently charging so I have to wait a little bit. :-( Weird you can't get the Market working. Try clearing the data from the Market inside the app manager. If it still doesn't work try a fresh flash of the ROM and gapps zips. Should do the trick.
Reactions: yota265
Data wipe didn't work. Already flashed the ROM again. Will try to flash gapps and see what happens.
Thanks
avromo
