[ROM]GingerSnap 2.3.8 10/25/12| 2.2 Rebuilt to 2.3
Heh. Ill send you a zip if I have time. My parents are all " Grt read to come upstairs " xD.
It will be untested though. :(
Sent from my LS670 using Tapatalk 2
Re: [ROM]-GingerSnap 1.3.5|7-23-12|Stock LG UI! Small Update!
decided to give this another try...accessing lcd density, screen notify and equilizer under additional settings are met with a FC.
Yes. I messed up the Update script, they are there, but not installed. I'm gonna sync with the latest Mirage, fix script, change Audio folder( I like the Xperia S ones.....Sorry ), and attempt to fix a V6 error.
Reactions: inceyet
Of course. If you want more, it's from here.
[CM7][THEME]Custom-ICS-Themes by Nutella [02.07.12] - xda-developers
I got permission to include it in a rom, so if you scroll in comments you might find me. :)
There are many different versions. There isn't a ICS patch for this rom, as it wasn't made. If you want one, I can make one, hoping it doesn't mess with the patch included.
So no update yet was hoping to see a fresh rom lol no biggie tho :)
Sent from my LG-VM670 using Xparent ICS Tapatalk 2
Will that minor update fix the broken settings for dsp manager & the rest off also im seem to be noticing battery drain isues but i bet its cuz my phone has been through alot including trying to commit suicide :D
Yes. The update script will need fixing. Battery drain, idk. I don't seem to have any. :-/
Just flashed this rom a few times on my OpV, and Im really liking it so far. Im wondering if there is something I need to do because when I click on any of the additional settings I am getting a FC, as well as changefont is not working....the stock font just doesnt look right for some reason.
Thanks for all the work, great rom.
Is this: http://forums.androidcentral.com/op...aded-7-8-6-gaming-beats-root-fix-updated.html the same as this rom? It seems to be I am wondering if it is replacing this rom. Also I don't seem to see the beats audio or bravia engine anywhere. The only songs that actually play loud and clear on my phone are in the market for playing a preview but songs I put on there are really quiet and can't barely hear them. Will the other rom work better for playing songs you add to the phone on the speaker?
This rom has them enabled by default. Beats, Xloud, and Bravia Engine.
It all depends on the quality of the music though. The GTR rom last update was in June I believe. This is the replacement, yes. Its supposed to replace it.
Lord Terox
