[ROM]GingerSnap 2.3.8 10/25/12| 2.2 Rebuilt to 2.3
Could this be any better!? Ginger Snap just got an update, OHSNAP! :P
Re: [ROM]-GingerSnap 1.3.5|7-23-12|Stock LG UI! Small Update!
I just noticed the same. Guess this adds one more update for you to work with. Seems like you are involved with multiple ROMs at the moment.
Update or not, keep up the great work!!:p
Uh oh! Looks like we have a problem.
Just downloaded the updated ROM, and the zip file is corrupt. Even checked it myself. When I cleared cache/dalvik and flashed it, nothing happened past the LG screen. Had to go back and reinstall 1.35. :(
Reactions: inceyet
I didn't update yet. :)
And which one did you download? 1.3.5 is the one in the OP.
When will the update be for our phones
@tgl do need to redo v6 again even if i did it on gtr
Good question. I really have no idea. :(
Gotta one more ? do u use the default rancher or a different one if so what cause i liked it status bar icons thanks
In a screen shot?
On GingerSnap I use the black status bar theme.
I use ADW Launcher or Xperia S launcher
Reactions: inceyet
In a screen shot?
Where can i get the black status bar theme
Update coming!
EDIT:
UPDATE IS UP
Download: http://db.tt/TwsIVqBA
Changelog:
Updated to latest Mirage
Included Xt9 database files by default
Added minor setting tweaks
And some of these
Reactions: irish-68 and bkttk2
Update coming!
EDIT:
UPDATE IS UP
Changelog:
And some of these
Click to view quoted image
Yes in getting it right now ...also in your screen shot how did you get those icons you said its in the theme sooo where is it at i can't find it and thanks for bringing this Rom to the ov
Once I get my sis phone activated (my ov) ima hook her up with this rom cuz it was always my daily :p
Sent from my One V using Tapatalk 2
judumo
