[ROM]GingerSnap 2.3.8 10/25/12| 2.2 Rebuilt to 2.3
Ok people. I have an update. This update doesnt fair to well.
MMS is broken
You cant enable Vibrate on keyboard or itll force close
You have to flash gapps after first boot.
If i fix MMS the rom doesnt boot. So its a little decision :(
Well that stinks, I was really looking forward too it
I'll probably check it out later though!:D
Re: [ROM]-GingerSnap 1.4.0 |8-20-12 |Stock LG UI! UPDATE!
Click to view quoted image
MMS is broken
Drat! Oh well at least you gave us 1.4. Thanks for looking into the 2.0 update.
This thing is awesome.
But then I mucked it up by restoring some app data for system files and I had to reflash. Now, no matter what I do, sd-ext does not mount.
I can manually mount it, but it won't auto mount.
Ideas? And thanks for the great rom. If I can get the sd-ext working it just may be my daily driver until the phone dies....it is that good.
I dont use SD ExT, so hopefully people here can help. I don't know anything about it :o
I use Link2SD and recreate the mount scripts. If I do a clean install, I redownload it from Play store and then add the SD-EXT. Make sure you enter the right partition type (EXT4 works for me). And yes, sometimes it can be a real pain in the butt!
I keep all my apps on SD-ext except L2SD, Titanium, Nemus, Auto Memory Manager and Play. For the internal apps, I keep extra apks on the SD card to reinstall.
Ill get it to work, as of now, Ill release what i have. The UI is 100% LG 2.0 :)
Hope to see an MMS fix very soon :).
It looks like a great ROM but I had to switch to another just because of the MMS issue. Once that is fixed this will be my ROM of choice. Thanks for all your hard work so far!
Doesn't matter to me.
I recommend Ginger Snap. But wait for GS 2.0. Its rebuilt and faster. Or use 1.4 :)
I was just taking a peek at the XDA thread on this, and noticed that LG 2.0 essentially replaces Nemus Launcher. Good thing I saw this before I proceeded further on my Nemus/Go themes.
Does LG 2.0 allow theming, or will it run other themes (like Go Launcher ones)?
Its more of it's own content. It has the default LG UI. 2.0, with the ability to save your screen setups and go back to one or another.
I'll release GS 2.0 here as a test build. I have 4 different test builds. 2 boots, 2 doesn't. So I need to know if I posted the wrong zip :)
Nice
I really like the keyboard, and everything seems to flow together very well
Hope to see mms fix soon
Just remember to NOT enable vibrate on keyboard. It?ll force close.
Download a different keyboard.
This keyboard is ported from an LG 2.0 device.
Re: [ROM]-GingerSnap 1.4.0 |8-20-12 |Stock LG UI! Testing 2.0
Ah, I guess that will work. I use Hacker's Keyboard.
I'll give it a go when MMS is fixed.
r3dpuk3
