[ROM]GingerSnap 2.3.8 10/25/12| 2.2 Rebuilt to 2.3
Couple posts up , mms broke but it's buttery!
Sent from my VM670 using Android Central Forums
Been using 2.0 test build as my daily. Seems to work nicely. Not sure in BT or MMS as I seldom use.
Sent from my LG-VM670
Re: [ROM]-GingerSnap 1.4.0 |8-20-12 |Stock LG UI! Testing 2.0
Anyone had issues with amphetamines 2 with this rom and how can I get it off. I've had to charge twice and my phones been on idle all day haven't even turn sent a text
Like Black Screen, Sleep?
I tend to have that problem, was your phone on 3G, or wifi?
Both, but I turn wifi off when not using it
I just made a thread, I had this problem 5 minutes ago on the bus.
Try holding the power button for 3+ seconds 5 times. It might come on.
Could I just flash rom again since amphetamines go to system, and over right the script
I suppose. Wipe System though. That's where the Tweak is at.
Sorry for dumb?( haven't sleep in 2 days.... yea insomnia, so brain is scattered) Would I just format system then reflash rom..... I'm on cannibal recover and data and system are one option to erase. Unless I go into mounts and storage and it has format "_______".
Make a backup. I could be wrong, and yes. Do not wipe Data if you still want apps you downloaded.
I'm a total amateur when it comes to customizing ROMs. I have tweaked a few prior to install, swapping fonts, a few system apps, etc.
I'm running GS 1.4, But I am itching to try an updated version of this one (I notice 2.1 for the P500 is up on XDA). Only dealbreaker so far, as you all know, is broken MMS. Any suggestions for a fix, such as a file swap (framework perhaps?) Or any kind of workaround to make the current version, with MMS, 100% workable for the Op V?
You can try using the Framework.jar from the previous build on the newer build.
If I mess with it, the rom doesn't boot.
I'm thinking that users could get much of the same effect of 2.0 by ODEXing their 1.4 Optimus V ROM. That seems to be where all the quickness and smoothness comes from. And for those who also want all the LG 2.0 stuff (I'll stick with Nemus), that could probably just be installed separately.
2.1 is by far the smoothest yet. Im trying to fix MMS for the system to boot
I cannot get 2.1 to install right. After installing, it gets stuck at the LG logo. I haven't tried 2.0 yet, I am still on 1.4.
Is this an actual V rom? It's posted under the P500 on XDA and I am running 1.3 with issues that shouldn't be there on a V.
Master zx
