[ROM]GingerSnap 2.3.8 10/25/12| 2.2 Rebuilt to 2.3
Your link for version 1.4 isn't working
The links work fine if you want equalizer and lcd then go to the gingersnap file go to data then go to apps folder and install the dsp manager and bird api
This is what I get when I click on link
I believe http:/ isn't a webpage ;)
Open with a different browser, or copy and paste it.
Gee never new http wasn't a web page:p got same thing with stock browser, dolphin, and opera, but gaps, and all links work
Got it to work( are they ever going to fix tapatalk)
Re: [ROM]-GingerSnap 1.4.0 |8-20-12 |Stock LG UI! UPDATE!
So, I wiped dalvik/system caches and flashed... I love the immediate snappiness and smoothness of this ROM.
However... half of my apps are gone?? :(
Help??
By any chance did you wipe data? Otherwise. That's the only thing that could delete apps.
Do you use and Link2ext or whatever?
No, I just wiped system and dalvik cache.
The apps still appear in manage applications, but with the standard android logo.
They look like what they would look like if they were on the SD and the SD wasn't in the phone.
You know what I'm talking about, right? D:
They don't show up in "My apps", either.
:confused:
Just placed a bid on a used ov hope I get it love this rom!
Sent from my One V using Tapatalk 2
It's nice, yes, but I'm on GTR and for some reason I just like it better over here.
To each their own!! :)
TGL
Just noticed Neko95 has updated GingerSnap to 2.0! Do you plan to update our OV version?
Thanks for all your work on this port!!
Ulaburgang
