[ROM]GingerSnap 2.3.8 10/25/12| 2.2 Rebuilt to 2.3
Re: [ROM]GingerSnap 2.2 FINALE | Optimus 2.0 Hybrid
Does the mms fix with gosms work on MIUI?
I changed the theme on MIUI to a different one, and now the lockscreen won't unlock. I'll continue trying though.
EDIT: Nevermind, I just reflashed. I really like this MIUI though/
Hold volume up and down plus home together! To unlock :D
Never used any Go Apps. I find it ti be bloat. You can try though.
And V up and Home/Menu. One of them. Like Toast said :) I think Down and Menu maximizes brightness.
I'm about to update GingerDX. Check this.
MIUI is fantastic! Great work on that! If you don't mind me asking, how hard will it be to fix MMS? Do you know what the issue is?
Phone FC. I just have to fix that and it's complete.
Cool. Hopefully you won't have too hard a time on that. :)
Yeah, I really enjoy the MIUI. I just wish it had screen shot in the power prompt
I'm about to update GingerDX. Check this. http://img.tapatalk.com/d/12/10/03/ba2e8a4e.jpg
I run go sms in light mode. And I don't have many apps installed anyways.
Power Prompt, change Page in status bar to Compact, or add the toggle. This rom has a screenshot toggle. ;)
I found that while I was at school. haha, too bad MMS doesn't work. Also, I was wondering. Do I have to do anything with APN settings? My data isn't working at all. Wifi works perfect, very fast. But I made sure my data was toggled and it still didn't work. When I tried sending MMS with GOSMS, the 3G icon showed up, but nothing when toggled or untoggled. You know what's up?
This is what happens when I use the MMS fix with GOSMS. Anyone that sends me a picture, I get this.
I'm having problems connecting to wifi on gingersnap, is anyone else? I've tried a second download, reflashing etc. it wont connect
Its the CDMA file. Ill fix it as soon as I have a clue.
Try rebooting. Or reconnecting.
Yes. Add a APN. Name it anything and APN code anything. Select it, reboot and now you don't have to do it again. :)
Ahh the famous lewa trick lol
Hey, TGL. By any chance is it possible to get the lg ui lockscreen on here?
Sent from my Android Ice Cream Sandwich of an OV.
Show me the lockscreen please? Is it the curved bottom looking one?
Im sure i can get help from CoolCatGetHome. He has a CM7 rom with a G2X themed lockscreen.
r3dpuk3
