[ROM]GingerSnap 2.3.8 10/25/12| 2.2 Rebuilt to 2.3
Re: [ROM]GingerSnap 2.2 FINALE | Optimus 2.0 Hybrid
I am loving this ROM. My only question....My home button is apparently not mapped. Should I reflash?
EDIT: Rebooted and everything is smooth!!!:)
You flash Gapps? It seems like 2 people had this problem so far. Try reflashing Gapps. If not, flash whole rom again+gapps.
I had not yet flashed Gapps. Once I did, all is well. This ROM is amazing. Thanks for the hard work you put it.
I'm working on MIUI GB atm. I plan to release in a few. It has no more lag, apps install with no problem, you name it. And a working MIUI Control Panel. Removing bloat and organizing zips. KCLS will love this! :D
Edit: Facing problems like GS. In MIUI, I just need to fix MMS without the Phone to FC. Then I'll release.
Download link is fixed. I had an extension URL on it. It worked for me on Tapatalk, but not PC. Odd.
Thanks guys. I should've listened to the other guy. Irish was it? :s
best battery performance ive seen in a while, it even "gains" battery sometimes. 15% remaining after 24 hours ( 5 hours of using copilot gps is in there)
Been running this ever since it was released and its been a smooth few days
Very nice
I've gone to this after ICS started getting really unstable. Love it, except when I applied the ICS theme, some ROM settings are gone. :(
Yes. Instead of flashing the ICS theme, download a ICS theme.apk and apply via theme chooser. The ICS theme in OP has Settings.apk which replaces the modded on in settings. :)
You have to options, Reflash rom, or pull Settings.apk and push to System/app/
Turly this is an amazing rom! Thanks for the update! Cant wait to test your miui Rom hopefully you get mms working!:D good luck!!
Current build(MIUI TEST) - http://db.tt/rIQKaXof
MMS fix = Phone FC. If this has Phone FC, wrong zip.
DO NOT LOWER BRIGHTNESS TO 0(BLACK SCREEN)
Is that a new dl?
I haven't had any problems with mms, is there an issue
Ohh sorry. Thats a MIUI GB build. Camera quality is crazy!
For our phone?
Yes. I took a couple of photos :P
Ah finally! Can't wait to see a full release! What's working and what isn't, so far?
Basically everything . I can use stuff like Solid Explorer, unlike before where it doesn't open at all.
Im gonna fix MMS when i get to figuring the Phone FC out.
richardgroover
