[ROM]GingerSnap 2.3.8 10/25/12| 2.2 Rebuilt to 2.3
Re: [ROM]GingerSnap 2.2 FINALE | Optimus 2.0 Hybrid
Can't seem to find a bug section does that mean it has no bugs and works good? Mms camera GPS audio etc?
Works great
Coo ima try it out once I wake up
Has anyone else had market issues with this ROM? Everytime I flash this one I keep getting "Device not Compatible" when I try to install something from the Market.
Np here
What are you trying to dl?
notice when trying to record audio from mms it crashes any fix for this?
No. Know. Bug. Its an actual LG 2.0 APP. Record using app then send.
You coming along with a fix for MMS on MIUI? I'm looking forward to it a lot!
I'll take another stab at it. I haven't touched anything sine TheKraven fixed Audio Routing on ICS with headphones: P
TheKraven gave me permission for one port. What would you guys like continued or ported?(Cm9)
I think you know that the answer to that is yes.
What is there to port?
Im alwalys up for a fresh flash:D
Yes, but what? MIUI, other CM9 rooms.
Miui
Sent from my Android Ice Cream Sandwich of an OV.
MIUI !!!!!!!!! :D:D:D:D:D
If mms is a sure thing i say miui
Oh and by the way TGL, I LOVE this ROM!!!!! Thanks :)
Sent from my OV
MMS on v4 should be easier than the GB I hope. If not, I just got another idea.
Miui v4 it is. I'll attempt it by next Monday. Weekend gives me a lot of testing time :P
Gapps work for the razr theme right?
s3 for the optimus V :D
richardgroover
