[ROM]GingerSnap 2.3.8 10/25/12| 2.2 Rebuilt to 2.3
Re: [ROM]GingerSnap 2.2 FINALE | Optimus 2.0 Hybrid
Yay MIUI :)
Is there anyway to get the home icons to lay 5 across like on other roms? I cant seem to find that setting?
Ohhhh!!!!!
Open app drawer. Click menu, edit a d then switch and swap. :)
Sent from my Motorola Triumph using Tapatalk 2
I figured how to edit the dock but still no 5 icons like other cm7's? Also, I hate this keyboard lol. Anyway to get the stock keyboard like gtr or cyanmobile uses? Other then that I'm pretty happy with this rom :)
It takes alot to download an run from what I read I got confused
s3 for the optimus V :D
You can add whatever keyboard you want
Sent from my VM670 using Android Central Forums
The store or pull them from another rom
What do you mean 5 icons? 5 icon dock, or Homescreen? This is an Official LG Launcher, fixed widget FC by Neko.
Keyboards, flashable zips are in OP! If not there, XDA thread.
Flash Rom, Then Gapps. The other stuff don't worry about. ;)
Where would I find them? Different keyboards?
OP, Market, Or XDA thread.
@ThatGuyLurkin, I mean 5 icon dock, like ICS docks. Is it impossible due to the LG launcher? Also, I downoladed and flashed the stock gb keyboard, then rebooted and still the LG keyboard.
Which one do I flash though
You need to go to settings / language and keyboard and activate
If you don't use Contacts that much, replace it with Browser or whatever you need there. I'm fine with just 4 :P
GS2.2 in OP. Then gapps. :)
Okay thanks, uhm is it stable?
Nazeer zaheen
