ARCHIVED: [ROM] - gROM 2.2 - 10/16 - GB - With Flash - Yes, FLASH!
Status
Not open for further replies.
Re: [ROM] gROM 1.1 - 9/16/11 - GB 2.3.3 [Official!] It just got r
Love to see the Power menu with additions and status bar power controls! Great ROM
Havinga weirrd issue where wifi will randomly turn off on its own.
Yes, that is strange! Let us know if you continue to see it happen...
Also, if anyone else sees it happen let us know!
Indeed!
Just an FYI: I am working on finishing up an Evo 3D project (24hrs from completion?) then I will try to whip up the next revision of gROM. I hope to include some of the suggestions like the power button and the pull down settings. Well see how it goes.
Reactions: WHYDavid and reltm
I'm noticing that gROM isn't playing nicely with ADW, it gets non-responsive when waking from sleep or returning to the home page from an app. It will work if you chose to wait, but it lags pretty bad at times.
Or you could say that ADW is not plying nice with gROM? lol
One suggestion....
Go Launcher EX!
Anything about having apps to sd working for zvh let me know try data2ext
No issues with ADW EX for me. Very snappy and no lag. Are you using Drew's kernel? It doesn't play well with this ROM.
Has anybody else experienced atrocious battery life since flashing this ROM or the GB update in general? I obviously did a factory reset before flashing so I have half the stuff installed than I did previously, but I'm getting half the battery life. Literally all I have running is email. Wifi and bluetooth are disabled. I'm getting about 8 hours of standby before it's prompting me to connect a charger (this is in a building wired for sprint, perfect reception). My only guess is that it's due to the sdcard mounting and unmounting constantly. I think I'm heading back to 2.2 for now.
Ya Iv been havinh some really bad battery life im only getting about maby 4hr out of it know like right now batt has onky been off charger for 3hr 4m an 19sec an im down to 29% not sure what to do iv done just about everything that I would do normaly to fix it an nothing
Charge it to 100% then wipe then battery then let it die completely and then charge it again then lsee if there is any difference
Ya iv already done that a few different times now still nothing lile I said iv done just about everything that I can think of an nithing not sure whats going I migjt take it in to sprint an see what they say
Try it
You can try collins battery tweak it work look for it on main threads
Last night I lost about 40% battery over about 6 hours.
One suggestion....
Go Launcher EX!
You could say that too. LOL
I'll give Go Launcher a try and see how I like it.
No Drew's kernel, I was but when it was discovered to cause all that double tapping and stuff I did a full wipe and reloaded gROM.
If you are using the timer for Battery Use, it's way off. See comments earlier about the problem. My battery life is fine.
Mines too lasted me all day even better with.the collins tweaks
I will give it a shot. My SDcard started to fail, I'm hoping not due to the phone, but I swapped it out now and haven't received the mount/dismount message yet.
Status
zolepso1
