ARCHIVED: [ROM] - gROM 2.2 - 10/16 - GB - With Flash - Yes, FLASH!
Status
Not open for further replies.
Re: [ROM] gROM 1.1 - 9/16/11 - GB 2.3.3 [Official!] It just got r
Problem with the widget positioning is fixed! Thanks. However, I too have the problem with the Power Control widget being blank.
Reactions: scrosler
duplicate post.
Re: [ROM] gROM 1.1.5 - 9/27/11 - GB 2.3.3 - Lets Rock!
Might be your card. The factory installed one had those issues on stock rom
I am not 100% sure it would be the SD card. I was on Drew's CM7 ROM and never had the SD Card issue except when I was running Sprint stock.
Maybe Drew has an idea on how that was resolved?
Maybe its a driver issue with Sprint ROMS? I have not had the problem so its hard for me to say. The last time I had the issue I formatted my card and it has not surfaced since.
gROM 1.1.5 bug:
The power control widget is wonky....
Power control widget is fine... Its the launcher, lol. You have to reboot one time like on CleanROM. I will put that in the OP.
attachment.php
I updated the OP :
[WARN]Read post #2 for important info BEFORE you attempt to flash this ROM! The flashing instructions have changed slightly![/WARN]
Then Post #2:
[TIP]How to Flash
Download ROM and place on the root of your SD Card
Boot into recovery mode
Wipe Data / Factory Reset
Flash ROM
Boot into OS
Once booted up and Set Up Wizard completes you must reboot one time to activate all functionality[/TIP]
Now... Lets see how many people ignore this and say the ROM is borked, lol!
Reactions: bertimus2002
actually, you can reboot a bunch, but until you place the widget there, it wont help ;)
Much thanks for your hard work. Can't wait to try this one out
so far nothing bad to report after a dirty flash.
The battery mod zip file download keeps failing for me. Any chance anyone could upload to another site?
I will later but you should contact a site administrator here at AndriodCentral if you are having download issues.
Is anyone else having issues with gmail syncing on time after the Gingerbread update? Often I will not get new email notifications until hours after they were sent. I can temporarily fix this problem by clearing all data in gmail but the problem eventually resurfaces.
In addition, after a few days my installed market apps disappear in the market and require a force stop of the market and a wipe of market data to show up again.
Has anyone else encountered this problem or have a long term solution to this?
I did not erase my data.......just cache/dalvik. Guess I'll do a full wipe but I hate re-setting my launcher layout and accounts.
Is there a gROM based off the official Froyo 2.2? I am still having issues due to GB. It's not gROMs fault, as I had the same problems with the stock 2.3...
Xenocide23 yep, gmail don't update neither does words with friends.
Don't go online to sprint support and try chat option, people there don't know crap.
Don't even know there was an update and that there are problems. lol
If you are referring to the launcher...
You dont need to wipe! Just reboot the phone after ROM install.
Hmmm.... I noticed something different with Gmail. Not sure what the issue was but it seemed to not want to notify unless you turn screen on. IDK for sure there. Lets see what others are saying about this. Could be another screw up Sprint made.
Yes, its called CleanROM. I no longer support or host it. I have a copy on my PC if you need it I can up it.
Sprint Reps in Chat not knowing what they are talking about? You jest!
alright i do not see a link to dl this anywhere? am i ******ed (maybe) or has it been pulled?
Status
byronsss
