ARCHIVED: [ROM] - gROM 2.2 - 10/16 - GB - With Flash - Yes, FLASH!
Status
Not open for further replies.
Re: [ROM] gROM 1.1.5 - 9/27/11 - GB 2.3.3 - Lets Rock!
The new market doesn't let me download a lot of apps and claims that they are "incompatible" for my device - including Facebook, Yelp, and QuickPic.
If I revert to the old Market, everything works again. Anyone has encountered this problem?
I just tried with the Market that is in the ROM and had no issues with Facebook, Twitter, Yelp and Quick Pick with no issues at all.
So it's probably because of the custom DPI then... heh :confused:
no custom dpi's in my themes. FYI
Tried the above app with no issues at all on my end either. so it might be your DPI.
Oh, I manually set it in build.prop as ro.sf.lcd_density=150.
What I did is I commented that line, rebooted, cleared out the Market Data, opened Market, accepted the agreement, and then uncomment the line from build.prop, reboot, and now I can download everything again... Hopefully the Market doesn't do a recheck on the hardware specs. Heh, I was wondering for so long why Facebook was incompatible with my phone given that I was able to use it before... funny..
I also made these to build.prop:
windowsmgr.max_events_per_sec=60
mot.proximity.delay=25
wifi.supplicant_scan_interval=300
Whats the gain in setting it to 15?
Text is smaller, so you get more real estate. It's like having a higher resolution, yet your physical screen is still small... :P
anybody else's gps not getting an accurate fix? the accuracy circle never gets smaller and it's off by about 2 miles. tried deleting data for maps with no luck. from other threads i'm guessing this might be a bug with the gb update and not this rom, is it something you would be able to fix in your next release or is it up to sprint?
I personally haven't seen the GPS off at all. Been pretty accurate for me. Lets see what others have to say about GPS.
Yeah it was noted in post 452: http://forums.androidcentral.com/lg...-27-11-gb-2-3-3-lets-rock-23.html#post1294522
Can I get a copy of the wallpaper you use for the latest build? I like it so much but lose it if I theme. Thanks.
I'm getting unbelievable battery life with this ROM. Great job, scrosler!
Battery life IS impressive...I want to get it overclocked soon, then the real benchmarks can begin. Can we get the HTC mod keyboard on this?
I'll post it tonight but if someone has winzip / winrar / 7zipi just unzip the file system/framework/framework-res.apk and look in the res folder. Its called default_background.jpg.
Glad to hear it!
As far as mods go I am trying to keep them to a minimum as I am trying to keep it somewhat stock with performance / usability enhancements. Now... That being said I am not adverse to create the mod as an add on pack. Can you give me more info about it?
Got it! Thanks a bunch. :)
Anyone else starting to get Not Enough Space message when installing large programs from the Market. I did a df from adb, and found I have about 12 MB available in cache partition. When I try to update large programs from the market (eg Angry Birds), I get this message.
Any chance data2ext will be available for gRom?
Never an issue when I upgrade from Amazon Marketplace.
yeah after a day and a half i am positive that this version has the best battery life out of any rom i've used on this phone.
I have not looked into it yet...
With the current market, trying clearing chace and dalvik in recovery. That might help you.
It very well could be. Gingerbread in general has better battery performance than Froyo.
Status
sellhousefastmke
