ARCHIVED: [ROM] - gROM 2.2 - 10/16 - GB - With Flash - Yes, FLASH!
Status
Not open for further replies.
Re: [ROM] - gROM 2.0 - 10/5 - GB 2.3.3 - O/C'ed - ROM Updater is
Should work fine on all connections.
And you are right.
Now its working
It might have to do with the wifi turning off when the phone screen goes off.
I JUST NOW notice the "talk back keyboard"... i wanna try!. but when i switch to it. it just tells me it refuses to cooperate.. how do i get it to work? or am i just trippin' and missing a setup of some sort
-Chris
Can you screen shot it? I am not sure. I just added the update from Google but did not test it. Assumed it would work.
-Chris
does it need a 3g connection?
Has anyone had this issue?
I'm on my first day of gRom. Did a full wipe/reset prior.
Every once in awhile my screen will shift to the right or left, and the right side of the screen comes about a quarter inch on the left side. I tried searching the thread but couldn't think of a keyword to search.
I toned down the OC to 712 max. Rebooted. Battery pulled. Not sure what else to do. thanks
Its something with the kernel that pops up for people. Not everyone sees it and Drew is working on it. According to his change log he believes to have it fixed in the latest release. You could try flashing the new kernel and let us know. If its good then I will update the ROM.
The rest of the Themes are now available in ROM Updater! Remember to hit the Check Now button!
Reactions: mike9670 and jstntp
Loving ur updater it rocks I'm using it with opti-rom an so fare everything is working. Downloaded a font an a theme.
SCOTT i give you some major props!! :D im loving your rom its all soo easy to use!! :D and im loving everything about it... though do you think its possible in your next release to add sd booster... not many people know about it but its one thing to OC the kernal but when u use sd booster it speeds it up just a bit more for those people that cannot OC to 806 like me... just a thought :D
Do you mean the SD Speed tweak script? IF so yeah, thats an easy add.
Re: [ROM] - gROM 2.1 - 10/8 - GB - OC'ed / Infinite Possibilities
[NOTE]
Changes in 2.1 - 10/8/11
  • Added: SD Card Speed Tweak
  • Added: More Fonts in ROM Updater
  • Udpated: GingerKernel 6.2
  • Updated: Market 3.1.6
  • Updated: ROM Updater
  • Updated: Host File
  • Removed: Talkback
[/NOTE]
Please hit the Thanks and Like button or better yet hit the Donate button!
I'm not able to get 2.1
Not Found
The requested URL /gROM_2.1.zip was not found on this server.
Not Found
Ummm... I was just kidding... It wasn't really ready.... :-[
Now its ready! lol Sorry about that! ;)
Reactions: manny29
Used the update thing to update to 2.1, put me in boot loop.
Let it sit at the circle animation for a few minutes, pulled battery.
Downloaded 2.1, put it on card, flashed it, still hangs up at boot.
Went back to 2.0. Thanks for your work.
Re: [ROM] - gROM 2.1 - 10/8 - GB - OC'ed - Infinite Possibilities
I finally remembered to take a second between flashing the ROM and flashing my preferred theme to turn on animations and check out the phone-lock animation. Pretty sweet!
@scrosler
Incredible! Do you ever sleep? It seems like you are putting out an update for one of your Roms everyday.
Sent from my Dell Streak 7 using Tapatalk
Very strange! Did you try to wipe data / factory reset before flashing the second time?
Are you talking about the CRT Power off animation?
@scrosler
Sleep? What is that? Ive vaugley heard of it before but not really sure what it is:confused:
lol, yeah, I sleep. When I run out of ideas for ROMS. But I try to keep content fresh. Who wants to run a ROM thats 2 weeks old? Might as well just stick with stock ROM if that is the case, lol
Reactions: manny29
Market felt and hero light font are,not downloading just wanted to let you know
And I did a dirty flash wipe cache and delvik then flash with no problem.....
Status
Maxyguy666
