ARCHIVED: [ROM] - gROM 2.2 - 10/16 - GB - With Flash - Yes, FLASH!
Status
Not open for further replies.
Flash is working great. Still have the gmail push/sync issue though.
I also turned off overclocking and am using the Savagezen governor and my screen sensitivity is a lot better.
Thanks for the update!
Interesting... I still dont have the screen sensitivity issue. I think its more of hardware revision issue. I really do. Some people find it to be an incessant problem others never see it at all. I only saw it once or twice.
so can i just use the rom updater and have it flash righto over everything?
Yep!
EDIT: Post #1000! Woot!
I played a flash video from youtube and if I rotate the screen it shuts off and I have to restart it. Is this a setting I need to change or a limitation of flash on our devices.
Other than that, it's another great revision running solidly since I got it. I'd still like to see the reboot and recovery options with the power button and power widget in notification bar and app grouping :)
I played a flash video from youtube and if I rotate the screen it shuts off and I have to restart it. Is this a setting I need to change or a limitation of flash on our devices. Other than that, it's another great revision running solidly since I got it.
I had no issues with rotation. But not doubting that you did have the issue. Not sure? But very glad its running well for you!
Well, if we are putting in wish lists... here's mine...
I'd like to see lots of donations... to help pay for my website and fast download server lol Which by the way is about to exceed bandwidth and get shut down soon!!!! A terabyte a week is a lot of data son! And that sort of hosting with the speeds it serves is a premium cost!
Also want to say that I am very thankful for the people that have donated!
But yeah, I will see what I can do... Later... This device has not seen service for months now so I am doing this just for the community.... My main device is the Evo 3D.
Well thanks for all the work you do. This rom really is great. I switched to optirom for a couple days because of the.built in storage but I missed alot of the features that grom has like the updater which is awesome so I came back. And to now have flash unbelievable work bro. Keep it up. Id def donate if I could.
Well, I am glad you enjoy my work and thank you for the positive feedback! I am slowly being persuaded into adding apps to SD. If someone wants to beta test an apps to SD version please send me a PM.
No appps to SD needed foe me. My iconia tablets does the apps now :-)
Gotcha. Was thinking about doing two diff builds. One of each... But... well see.
awesome >> scrosler
Techincally in a mathematical perspective that statements means I am less than awesome. as written ie means "awesome is greater than scrosler" or conversely "scrosler is less than awesome".. But I think I know what you meant... lol (geek humor)
Anyone else have wireless tethering issues? Tried two different apps and no luck any idea?
Nope works great for me. Are you using the included Wireless Tether app?
For me when i start the wireless tether app for the first time it says configured but with errors, check log for details. I go to show log, and the majority say done, but
Configuring softap..
Failed
Starting softap...
Failed
Activating wifi interface...
Failed
All other points it says done. But i do not get the reboot using the app. It shows that it is running, but nothing can see my network.
id try the apps 2 sd but my sd card is really old and i was having problems when i tried it on optirom though it would be a nice feature to have.... though most of my problems were with the market saying i didnt have enough space but that may have been a market issue but i couldnt find how to solve the issue so i just gave up lol
thanks scott for the awesome rom love it flash support awesome :) hope ya get the power thing in the notification bar drop down goin that be cool and could ya get me the sprint zone apk thats the only sprint app i like thanks gROM rocks
One more thing, guys does this ROM come with apps2sd baked it ? Can it be run on this ROM, if so does anyone have a link or know the name of which one works/
TIA
TIA
No but you can easily add it. I dont have any links but look for "darktremor" and that will get you going where you need to go.
Status
BeshevGames
