Re: [ROM] Harmonia 1.3.1 (Aphrodite+Picasticks) 16July11 (2.2 bit
No idea, maybe you had another overclock utility installed.
First of all, I want to thank you,
LeslieAnn for putting together such an awesome rom! I know I should have read more on overclocking before I tried it. Most of what I did was just follow this guide:
http://forums.androidcentral.com/optimus-v-rooting-roms-hacks/101466-how-setcpu-profiles.html
The only overclock utility I installed was setCPU (unless one was included in the rom, which I don't think there was). Currently setCPU is uninstalled, but there's still a backup of it in "titanium backup." I am detecting CPU status with the "Temp+CPU V2" widget.
In trying to revert to original settings, II have done everything
crpeck listed below, but the CPU setting still remain:
wipe data/factory reset
wipe cache partition
mounts and storage: format boot, system, data, cache
advanced: wipe Dalvik Cache
wipe data/factory reset again
wag the bag of chicken bones over my head
install zip Harmonia 1.3.zip
install zip Harmonia_1.3.1.zip
install zip Harmonia_1.3.1.zip (yes, again)
install zip Harmonia_Maps_Patch_July_5.7.zip
advanced - wipe Dalvik Cache (again)
reboot
I suppose the only way to control it will be to use setCPU...
Any idea what the default settings are? maybe i can just set them to default with setCPU or make better profiles on it.
