[ROM] Harmonia 2.09 18July12 (IHO Gingerbread)
I just flashed the akop and got it set up to login and see an update. Thank you leslie. Downloading now
Sent from my VM670 using Tapatalk 2
Re: [ROM] Harmonia 2 (IHO Gingerbread) See first post for updat
I'm pretty sure the theme chooser is still there.
Whoa! How did I miss this? Why, I could've been flashing two hours ago. I'm going in.
Nice! New animations. And am I wrong, or is the pull-down notification transparent where it wasn't before?
Oh, wow. Custom text on the lockscreen. Been wanting that for a long time. Beautiful.
my contacts wont sync does anyone no why
Same here. My Google Contacts would not sync. I have flashed several other IHO ROMS and no problem. I tried 3 times with total wipe and no go. So I am using mgr666. Any suggestions?
Edit - I tried the rev on the github page. I will try 2.06 and see if that makes a difference.
Edit 2 - Flashed 2.06 and Google accounts will not sync. Google play log in works but gmail, google contacts do not sync. Flashed back tomgr666 and all is well.
Downloading this as soon as I get to a computer to make my usual adjustments. These new features sound really exciting :) For those having trouble with Google Contacts syncing, you might want to just export your contacts then import them post-flash, am I right?
Contacts will only sync once the phone sits idle for a moment, Google made some changes to it, I think.
Otherwise, you have a bad flash.
Hey I cant download from Mediafire... They shut down? Is there a mirror? TY :-)
They have been having issues.
Try again.
I thought bad flash initially. I tried new down load for re-flashes. I try to sync on (fast) home wi-fi and gave it about five minutes. I have tried three of the other IHO options on the github page and all syncd up with out problem in a minute or so. Maybe I should have given it more time? Fix Permissions?
The upgrade instructions on page one only cover up to 2.04. Since I have 2.05 will I need to do a complete wipe?
I did the suggested wipes from this list and had an easy time:
To upgrade from 2.0B,2.0, 2.01, 2.02, 2.03,2.04, go into "mounts and storage", wipe cache, systems and boot, go into "advanced" and wipe Dalvik, then flash.
If you have issues, do a complete wipe. All others do a complete wipe.
But I was coming from 2.03 so... yeah. Guess that doesn't help you.
If you came from her rom then you do an upgrade wipe, all other roms need to do a complete wipe. I personally always do a complete wipe just to not have any problems at all.
I have. version 2.05 is 2.06 really worth my time flashing?What's the difference?
I notice my purchases aren't showing up in Google Play, I've wiped and reflashed twice, left it idle, nothing's working. Is this related to the contact sync issue?
Like I said, it seems to wait until things are idle, but if it still won't sync, go into your account settings and make sure it is set to sync.
Also, If your primary account is not a Gmail account and/or you removed the Gmail.apk, you may need to go into there and make sure that is setup. Not sure but it seems like Google messed with that too.
Correct and I will update the first post.
I think it is.
Clear Market data, that should fix it.
miyonfaga
